ABS switch
ABS switch
what do u think of a switch to turn off the abs
TBH I have to say that would be potentially very dangerous: first of all the ABS system is solely responsible for acting as a pressure regulator for the rear brakes as there is no separate load-sensitive limiting valve for the rar brakes on these cars anymore.
So if the ABS was to be be deactivated, the braking pressure to the rear wheels would no longer be regulated and you could end up with dangerously rear-biased brakes. With the possible (and likely) consequence of the car spinning instantly the moment youd be slamming the brakes any harder (in a panic stop for example)!
