Clunk felt through steering column?
Don
Postby Don » Mon Jun 25, 2007 8:01 am
Just noticed a small 'clunk' through the steering column while coming off full lock, not there when you turn the wheel left to right quickly (not going to full lock). Something is amiss and I thought I read something about this a while back but cannnot find it.
Is this a known issue? :(
Cheers,
Don
Postby AlexB » Mon Jun 25, 2007 11:33 am
Yes, it's a known issue discussed earlier, unless you've got something else. It is not safety critical, but needs to be done anyway. The fix involves application of some sort of resin compound to a joint and replacement or re-tightening of a bolt. I can't remember the particulars now, but it was a quick job (an hour or so) under the warranty. Webcode described the details -- search his messages.
Don
Postby Don » Tue Jun 26, 2007 8:11 am
Cheers Alex, will drop webcode a line!
cactusbob
Postby cactusbob » Tue Jun 26, 2007 9:11 am
It's your steering pinch bolts. Take it to your Stealer and they'll fix it for you
225 5dr FF + Xenons
http://www.meganesport.net
Users browsing this forum: No registered users and 54 guests
