Change Oil warning message still showing
sam101
Postby sam101 » Wed Jun 20, 2007 1:39 pm
RE: Megane 1.6 vvt
The change oil warning message came on last week and Ive just taken it into Kwik fit to change the oil/filter.
However the warning message has not reset and Kwikfit are telling me they cant help with the electronics. Is it possible to reset this myself or is it a job for another garage...
IainMW
Postby IainMW » Wed Jun 20, 2007 2:54 pm
Scroll through on the trip computer until it displays change oil soon and then press and hold the mileage reset button (on the speedo) in until the display resets to 18000 miles or whatever service interval your car has? this can take a few seconds.
robznet
Currently Drives:: Megane 1.5dci
Postby robznet » Wed Jun 20, 2007 11:03 pm
Hi Iain
Does this reset work with all models?
Worth knowing when your car is out of warranty (as kwik fit said - they cannot help with the electronics)
Would be a good pointer for all members! :D
Regards
Rob
1.5DCi Dynamique with comfort pack - Antique Green.
IainMW
Postby IainMW » Thu Jun 21, 2007 7:35 am
Yep it does work for all models
Forgot to mention, you need to hold the mileage reset button in until the display has stopped flashing.
Hologram
Postby Hologram » Thu Jun 21, 2007 10:54 pm
My 06 1.6 does not have the button on the speedo to reset the mileage. My old car an 03 model did. My Change Oil Soon is lit and has come on far too early. :x
IainMW
Postby IainMW » Fri Jun 22, 2007 11:01 am
How do you reset your odometer then?
You have to remember that the service intervals are based on mileage and time period.
e.g. 12000 miles or 1 year, which ever is sooner?
The time period is set from when the car is built, not the date of first registration.
rach74
Postby rach74 » Fri Jun 22, 2007 11:29 am
MY 53 Plate meg saloon had the little button but now i have an 07 meg priv cc and to change the odometer or anything else on the computer you keep your finger pressed in on the button on the right stick, (the button you use to flick throught the computer) just keep it pressed in for 5 secs and this clears it
hope this helps
Hologram
Postby Hologram » Fri Jun 22, 2007 11:17 pm
I can reset the usual data by holding in the button as you say. I have not been able to get rid of the Change Oil Soon message.
As I mentioned before, my car was a factory order and I had to wait until 29th July last year for delivery. I was somewhat surprised that the message appeared in May. Mileage then was around 7000
Seems odd to me.
WebCode
Postby WebCode » Sat Jun 23, 2007 9:22 am
On the facelift models (06) you have to scroll throught the computer trip as with the old model but then press and hold the button on the end of the right hand stalk to reset the change oil soon message..
Users browsing this forum: Google [Bot] and 56 guests
