Washer Jets :-(
andrew_s46
Washer Jets :-(
Postby andrew_s46 » Mon May 21, 2007 7:22 pm
hi,
my washer jets have recently stopped working. although sometimes they do work it is a very small squirt at the bottom of the screen. sometimes it does not squirt at all.
whenever i pull the stalk to active the washers i can hear the motor trying to pump the water.
any ideas what it could be?
L77
Postby L77 » Mon May 21, 2007 7:28 pm
Check your water bottle aint bust.
____________
________
____
L77
IainMW
Postby IainMW » Tue May 22, 2007 7:53 am
The pump has probably gone!
Not an uncommon problem
Jonault
Postby Jonault » Tue May 22, 2007 9:35 am
Compared to other cars that I have owned over the years, the washers are feeble. The wiper blades have usually run over a dry windscreen twice by the time the water appears. I assume this is normal for the megane. The rear screen takes even longer for the water to come through!
John
andrew_s46
Postby andrew_s46 » Tue May 22, 2007 1:05 pm
hi
i sorted it! htanks for your help anyway!
seems as though the pipe was being kinked at the top of the engine bay near the hinge - i simply relocated the pipe and 100% powerful!
Jonault
Postby Jonault » Tue May 22, 2007 1:11 pm
I must check my pipe routing. I may have been putting up with rubbish window washers whilst thinking this is the norm for a megane.
Users browsing this forum: Bing [Bot] and 28 guests
