Engine Misfire
Cas1011
Currently Drives:: Megane 2 1.4
Engine Misfire
Postby Cas1011 » Fri Dec 20, 2019 5:29 pm
Hi all,
New to the forum and need to pick some brains...
Megane 1.4 started misfiring and running lump on Wednesday, changed all my plugs and 1 coil pack. Started up and 2 days later started misfiring and running lumpy again, bought a diagnostic checker and it read P0300, doesn’t point to a specific cylinder.
Any ideas? Plugs are new, leads have voltage.
My next job would be to replace the other 3 coils but I have a feeling this won’t solve it.
Any help would be greatly appreciated
blazemaguire
Re: Engine Misfire
Postby blazemaguire » Sat Dec 21, 2019 5:22 pm
I'm sure you've checked, but mine just last week one of the wires that runs to the coil pack had corroded about 30mm away from the coil pack under the plastic sheath.. It actually looked like the sheath had been cutting through the wire over time rather than protecting it. Mine was facing down so not visible immedialty, but was literally one strand of copper sending current to the coil
DougM
Currently Drives:: Megane 2 1.6
Re: Engine Misfire
Postby DougM » Sun Dec 22, 2019 12:25 pm
Did you use dielectric grease when you changed the plugs and coil?
Cas1011
Re: Engine Misfire
Postby Cas1011 » Mon Dec 23, 2019 6:05 pm
Diagnosed as a bad fuel injector, would you know what injector it would be as there is litterally hundreds to choose from.
scooper1000
Currently Drives:: 2006 Renault megane 1.5 DCi Maxim
Re: Engine Misfire
Postby scooper1000 » Mon Dec 23, 2019 7:09 pm
do not know much about the petrol model, I would have thought the fuel injector would be one of the 4 injecting the fuel into the cylinder, though i could be wrong SORRY NOT MUCH HELP REALLY though if your asking which specific injector your car is fitted with I would suggest removing one and look for marking on it..
DougM
Re: Engine Misfire
Postby DougM » Tue Dec 24, 2019 3:53 pm
I would imagine a quick call to your local dealer armed with the registration would reveal exactly which injector you need.
Users browsing this forum: Google [Bot] and 57 guests
