Having a right problem with tail light drivers side, brake light is working but tail light is not I’ve changed the bulb 4 times so I can’t be the bulb must be something else
Also drives side light at the front has gone out since this has happened ?? Real pain
My number plate late lights also not working I’ve even changed the whole fitting ?
Any help cheers
Megane 2008
1.6 dynamique
5 door
Problem with tail light drivers side
- Currently Drives:: Megane MK2 04
Re: Problem with tail light drivers side
I am pretty sure i had this problem, check fuses in engine bay.
[quote="mforan2016"] will I have to take battery and Ecu etc out to do this ?
the battery will have to be removed the ECU can stay where it is
Users browsing this forum: No registered users and 65 guests
