Bcm replacement
Mtb
Currently Drives:: Megane mk2 convertibel
Bcm replacement
Postby Mtb » Mon Jul 24, 2017 6:59 pm
Hi everyone ,
I have bought a new bcm for my 1.5 DCI , I read it can be plugged it , it won't start the car without programing is my understanding , but from a post I read if u plug it in then u should still get things working , interior lights and so forth.
I plugged my new one in to test it and nothing :( any electrical faults I had are still there ....
Anyone have any ideas , I'm losing the will to live with this problem
Melanie
grandadbobby
Re: Bcm replacement
Postby grandadbobby » Mon Jul 24, 2017 11:46 pm
Hi Melanie,
that's the BCM eliminated, you could put the original one back in.
The faults must be isolated incidents and need addressing one by one.
Can you post what doesn't work and confirm that the car starts ok.
lt would be good if you can give any fault codes stored also. There should be one for the abs for a start.
Also, has anyone tested the brake light switch ?
Bob.
Mtb
Re: Bcm replacement
Postby Mtb » Tue Jul 25, 2017 12:11 am
Hi Bob ,
Thank you for taking the time to reply . functions not working are :
Back wiper
Front and rear washer pumps
Heaters
Brake lights
Interior lighting
Speedo
Abs lit in dash
Boot won't open
So far , brake switch replaced , diag done and that's all I was told was there is no power going to the abs, I asked about the brake lights and such and was told they are out because the abs runs them ?? Not what I thought to be honest.
Fuses checked , new under bonnet fuse box put in and new bcm and still no resolve :( :banghead car starts with no issues and runs with no issues
Melanie
grandadbobby
Re: Bcm replacement
Postby grandadbobby » Tue Jul 25, 2017 1:39 pm
To make a start, can you check if the rear fog light works, you need the head lights on to do it.
Bob.
