1.5dci egr...yeah, i know!
callyspoy
Currently Drives:: Mwgane 1.5 dci
Mazda Bongo
Suzuki b120
Postby callyspoy » Mon Jul 11, 2016 2:21 pm
Hi folks,
My 2005 1.5dci Megane has a lumpy idle, not always, but quite often. If you increase revs to 1000, it disappears.
Before i start weeping that it may be DMF, I would like to check out the egr.
Can you confirm that this is the egr, top centre in the picture please.
I am due yo do an oil change, so fancy doing both at the same time.
Many thanks
Callum
taffyhl
Re: 1.5dci egr...yeah, i know!
Postby taffyhl » Tue Jul 12, 2016 8:17 am
I've a 1.9dci so cant say....but does look correct. Suggest checking the manuals linked to above.
My DMF is on the way out - confirmed when the timing belt was changed where a slight 'give' in the springs was note by the mechanic. This doesn't cause me rough idle (blocked EGR valve did) but it is noticeable when accelerating between about 1000 and 2000. You can feel a wobble which implies misfiring. Mechanic suggested waiting until it's completely gone as this can take a long time, maybe years!, and by then the car probably will not be worth spending money on...it's already 12 years old with 134k.
He quoted £500 to change DMF and clutch BTW.
callyspoy
Mazda Bongo
Suzuki b120
Postby callyspoy » Tue Jul 12, 2016 12:53 pm
Thanka for the info.
Yes clutch feels fine and no wobble or anything once off idle, it's only done 48000, so a lot of stop start, so i expect some blocking of bits n bobs!
I'll have a look at the egr this weekend then, thanks again.
ikhan
Postby ikhan » Sun Jul 24, 2016 4:47 pm
callyspoy wrote:Hi folks,
Many thanks
Callum
Is this the 106bhp engine? If it is, could you post up a few pictures or a small write-up on how it's removed. The set up on the 106bhp seems to be different to the 'how-to' on here and I've been lead to believe you have to remove the firewall for proper access.
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
callyspoy
Mazda Bongo
Suzuki b120
Postby callyspoy » Tue Sep 13, 2016 8:00 pm
Finally had a chance to do this today.
Easy peasy on my wee 1.5! Three bolts, egr out. It was pretty coked up in there, not sure if it was stickung, but it is clean now.
Turns out my main worries were perhaps O.T.T.
My rattley engine was exhaust hitting heat shield! The clicking steering was sorted by tightening the bolts holding the rack to subframe.
So a great Meg day, for a change!
q292u
Global moderator
Currently Drives:: 2003 Clio. The Megane died.
2001 Audi A2 1.4 SE
Postby q292u » Thu Sep 15, 2016 11:02 am
taffyhl wrote:I've a 1.9dci so cant say....but does look correct. Suggest checking the manuals linked to above.
What's a DMF?
q292u
Global moderator
2001 Audi A2 1.4 SE
Postby q292u » Thu Sep 15, 2016 11:17 am
Many thanks
Callum
I had a Fiat Punto for years. never needed to do an oil-change, as it leaked so much, it was like a continuous oil-change.. :)
callyspoy
Mazda Bongo
Suzuki b120
Postby callyspoy » Thu Sep 15, 2016 2:46 pm
Ha, fortunately the Meg seems to retain it's oil, but it certainly is still due a change. I have the filter and oil, have done for 4 months. But my daughter was born nearly 4 months ago so time on car is a bit short.
DMF is th dual mass flywheel. A scary contraption that i have zero interest in replacing myself if i can help it!
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 67 guests
