Hi Gareth,
The "Megane 2 Roof Problems" my "problems"took me 6 months to finally suss out what sensor was causing the roof to only half open then stopping,got it off to a fine art of catching the half opened roof then press the roof rocker switch on\off really fast ,it would then go back in small amounts
until it reached the over head part,then it slowly lowered it self into the boot under hydraulic pressure,
I drove it like this for 3 months with the only inconvenience beeing the "Manual Close"each time,Taking the 3rd fuse out from the bottom of the passenger fusebox became a daily chore mastered even in the dark,but lifting that heavy glass roof on your own is challenging at first.
If you are still having problems let me know and I will try and help as I pretty much know the workings of the sensors inside out after 6 months spent researching,searching with out much joy for any CC Roof related stuff.To be fair I only mention 6 months cos the tax disc needs renewing and thats about when I last remembered pulling off my drive and not having the bleedin buzzer telling me my lifes about to end due to "Check Sunroof" error
Anyway its now pleasing to hear the "Roof Operation" Thumbs Up chirp everytime,so if I can be of help to anyone with Roof Woes just ask even made my own cables for the flimsy parcel shelf and played around adjusting them to achieve that sweet spot where it closes just in time,.well pleased as my work ethic is to fix it myself eventually and ringing the "Main Agent"is out of the question,plus my cable mod eliminates the dreaded cable pull through its crap plastic fitting on the boot arm when the opposite cable breaks
Sandro
Roof Diagram
- Currently Drives:: 2006 Megane CC 1.9 DCi 130 BHP,6 Speed in Silver
2006 Mitsubishi Shogun Warrior SWB 3.2 DiD in Black
+ Half a dozen Motorcycles
- Currently Drives:: Megane cc
Re: Roof Diagram
garthewise wrote:My local parks kindly sent me a diagram of the roof working ect.. When I explained to them that I want to know where sensors were. Pictured is what they sent me. I then asked for something that had parts and number description. Witch failed to be produced. (Typical) so if this can help anyone and Can explain parts to me![]()
Hi
There's no picture, could you put this up as I would be interested
Many thanks
Darren
- Bertl
- Currently Drives:: Renault Megane II CC Dynamique 1.6
Chevrolet Lacetti SX 1.4 Saloon
Re: Roof Diagram
Evoluzione wrote:Anyway its now pleasing to hear the "Roof Operation" Thumbs Up chirp everytime,so if I can be of help to anyone with Roof Woes just ask...
Sandro
Hi Sandro,
I posted this question already in another thread, maybe you have an answer for me??:
today the error message 'roof mechanism fault' appeared.
After some tries I could isolate the fault - when the boot lid is closed after closing the roof apparently the hydraulics does not get the message 'lid is closed, stop pumping' but continues to pump. Also the electronic seem not to get the 'lid closed' message and shows the error message then.
The hydraulics continues to pump for some time until the pump gets quite hot and cuts off.
So somewhere there has to be a sensor that sends the 'lid is closed' message to the hydraulics and electronic - does anybody have a clue where to find this sensor or where the 'lid is closed' message comes from?
_________
as ever,
R.
as ever,
R.
- Currently Drives:: Renault Megane cc 1.6......Project
Audi A1
Kia Picanto
Beetle 75 Restomod
Triumph Spitfire
Re: Roof Diagram
Hi There
I have just recently re purchased a cc that I sold 3 years ago and the previous owner has absolutely neglected her.
In my efforts to save another cc I need to go over her roof operation from start to finish.
Any diagrams, manuals or directions you could point me in please ?
- Currently Drives:: Megane 2 cc 1.9 dci
Re: Roof Diagram
Hi, I've got a mk2 cc. The roofs works however the folding parcel shelf is missing. I'm guessing this has been crushed along the way. My question is... If I bought a new one are they easy to connect and should it be connected to another cable to operate the wings?
Thankyou in advance.
Mark
Mark
Re: Roof Diagram
Can I get some help please?? The roof on my megane opens then stops, opens a bit more then stops, then it hides itself away in the boot and stops, the boot remains open and the parcel shelf in the air!!! Then u have to pop the fuse and manually put it back up!!! Any help would be much appreciated!! Thanks in advance adz
Re: Roof Diagram
Evoluzione wrote:Hi Gareth,
Sandro
