Hi all sonic been having some problems with the motor
There is no power to the fuel pump
I've checked all the fuses
The relay is built in on this model so can't change easily
What can cause this and how do I fix it
It's definitely an intermittent fault as I had the car seen to at the side of the road to get home
He ran a wire from a perminant live to a switch and then to the fuel pump
Switch off no start switch on starts fine
Sometimes if u switch of the pump with sed switch while running the car it's fine and idles fine
Thanks hope u can help
No power to fuel pump
Re: No power to fuel pump
viewtopic.php?t=20088
Might be worth contacting this member if they are still active , similar problem.
Users browsing this forum: No registered users and 71 guests
