Renault Megane II AC not blowing air
Khaleal
Currently Drives:: Renault Megane 2
Postby Khaleal » Thu Sep 17, 2015 6:41 pm
I have a Renault Megane II 1.6 16v 2005. Recently the AC stopped working completely.
When I turn the AC on it doesn't blow any air (cold or hot) but I can hear the compressor kicking when I rotate the AC from 0 to 1,2,3,4. The AC pipes are cold.
I've inspected the fuses under the steering wheel and all seem fine. I've never checked the fuse box under the hood.
What could cause such thing?
Your help is appreciated :)
cba
Currently Drives:: Megane MK2 2004 + Several Motorbikes
Re: Renault Megane II AC not blowing air
Postby cba » Thu Sep 17, 2015 10:30 pm
Khaleal wrote:Hi,
Does the fan work at all? Even with the AC off?
Khaleal
Postby Khaleal » Fri Sep 18, 2015 6:40 am
cba wrote:
Khaleal wrote:Hi,
If you mean the front fan of the car then yes it works. The heater blower fan (which is located behind the glovebox isn't working at all)..
cba
Postby cba » Sat Sep 19, 2015 10:40 am
Khaleal wrote:
cba wrote:
Khaleal wrote:Hi,
We are talking about the A/C here. I see no reason why I'd be talking about the radiator fan!
Anyway, lol, it doesn't work at all leads me to believe that the resistor connector has melted.
Good news - your car hasn't caught fire.
Bad news - It'll cost about £40 to fix (if you do it yourself with eBay'd parts).
My local Renault dealership wanted £31 for the cable and £65 for the resistor. eBayed the lot for £35.
https://www.ebay.co.uk/itm/361360210721
https://www.ebay.co.uk/itm/271584116152
Search around but that's about the cheapest you'll get.
Let me know if you need a details explanation on how to remove/replace. It's easy to do, however.
Khaleal
Postby Khaleal » Sat Sep 19, 2015 12:26 pm
Thank you for the detailed answer. I really appreciate it.
Where are these parts located in a left-hand drive Megane II 2005 (Saloon)? I've disassembled the glove-box yesterday (where the cabin filter is and wasn't able to find any of those parts)..
cba
Postby cba » Sat Sep 19, 2015 1:27 pm
Khaleal wrote:Thank you for the detailed answer. I really appreciate it.
Remove the glove box, reach behind the centre console and you'll see the fan. It's probably easier to remove the fan. If you can wait, I can probably take some pictures?
You need a star screwdriver to take the resistor out (two screws).
I believe the saloon is the same as the hatchback.
Khaleal
Postby Khaleal » Sat Sep 19, 2015 2:54 pm
When I removed the glove box I found no way to remove the fan as I couldn't find/reach any bolts/screws securing the fan.
I can absolutely wait. Some pictures would be useful.
I've watched this video: https://www.youtube.com/watch?v=XI2MJl8W0yE
But my car isn't the same as shown in the video. I mean, When I remove the glove box I don't see that amount of cables and screws. I'll try taking some pictures as well.
cba
Postby cba » Sat Sep 19, 2015 3:21 pm
Post some pics asap. I'm just watching the rugby. Once done, and once I've seen your pictures, I'll get you better video/pictures explaining what to do.
Users browsing this forum: No registered users and 42 guests
