radio code
johnny the fox
Currently Drives:: 54 metalic dark blue megane dci 120 sports estate 40k miles since new (my trusty tractor) owned sinced july 2010 i do about 3-4 k miles per year
radio code
Postby johnny the fox » Sun Jul 19, 2015 9:25 pm
hi all, i had to replace my battery and i haven't got a radio code. can anyone tell me the easiest way of obtaining it and if poss free of charge? kind regards Johnny
freelanderuk
Re: radio code
Postby freelanderuk » Mon Jul 20, 2015 5:55 am
If you have an android phone look on the play store for Renault radio code generator , down load and enter the code of the radio and it will give you the security code :D
Drive it like you stole it
My flickr
johnny the fox
Re: radio code
Postby johnny the fox » Mon Jul 20, 2015 7:07 am
i haven't got that type of phone but my daughters have i phones. would they do the same job? cheers johnny
freelanderuk
Re: radio code
Postby freelanderuk » Mon Jul 20, 2015 7:40 am
i think there is one for apple also
My flickr
funkyunderpants
Currently Drives:: 2007 Megane 1.5Dci
Re: radio code
Postby funkyunderpants » Sat Jul 25, 2015 12:32 pm
If you don't manage to get hold of the app just post the barcode from your radio here and myself or somebody else will provide you with the correct code.
johnny the fox
Re: radio code
Postby johnny the fox » Sat Jul 25, 2015 8:50 pm
hi ya, ile try and locate it. sounds like ive got to take it out? cheers johnny
johnny the fox
Re: radio code
Postby johnny the fox » Sun Aug 02, 2015 7:33 pm
Hi ya, ive had a go at getting the radio out but to no avail. I assume i have to remove the radio via the 4 small holes at the front of the set. what exactly do i need to do to achieve this as i have tried various small screw drivers but with no luck? regards,Johnny
Re: radio code
Postby Stranger » Sun Aug 02, 2015 7:36 pm
johnny the fox wrote:Hi ya, ive had a go at getting the radio out but to no avail. I assume i have to remove the radio via the 4 small holes at the front of the set. what exactly do i need to do this as i have tried various small screw drivers but with no luck, regards,Johnny
Some stiff wire that you can bend in to a U shape (an old wire coat hanger is ideal for this).
You'll need to make 2 U shaped pieces, one for each side push them firmly into the holes and they release a flat spring which holds the radio in to the casing and then wiggle it out slowly so as you don't rip any connectors off.
adrianmartin
Currently Drives:: renault megane scenic 1.6
Re: radio code
Postby adrianmartin » Wed Aug 12, 2015 4:32 pm
Hi there just had full valet and got electics wet after much wd40 on fuses for which I had to take BATTERY
out.have the no but no smartphone if someone can help me out would be grateful.
no is 8200300858TR104
freelanderuk
Re: radio code
Postby freelanderuk » Wed Aug 12, 2015 4:44 pm
try 8852
My flickr
Philthy
Currently Drives:: Megane Scenic 1.9DCi
Re: radio code
Postby Philthy » Fri Aug 21, 2015 8:03 am
I have the keycode generator if it's ok to link to it?
Irishrenault
Currently Drives:: Renault megane
Re: radio code
Postby Irishrenault » Tue Sep 29, 2015 7:15 pm
Hi I'm looking for assistance in unblocking my radio. Details are
8200607918TT108
RNRDBE80852405
RENRDW330-10
FD0908250852405
tanto12
Currently Drives:: 2005 megane sport tourer
Re: radio code
Postby tanto12 » Wed Sep 30, 2015 3:27 am
hi Irishrenault
radio code 6839
if at first you don't succeed get a bigger hammer
Irishrenault
Re: radio code
Postby Irishrenault » Wed Sep 30, 2015 12:42 pm
many thanks
Sparklylisa
Re: radio code
Postby Sparklylisa » Sun Oct 04, 2015 4:23 pm
Hi everyone, I can't seem to find the app on my iPhone??
Does anyone have a radio code for a Renault Megane serial number 8200483757T
Bought it off my cousin and he said he had to disconnect battery so has lost the code and never had a service book, any help would be greatly appreciated
Thanks in advance :-)
