tie rods
phil48
Currently Drives:: megane estate
tie rods
Postby phil48 » Sun Jan 25, 2015 4:37 pm
anyone know hows the best way to change the tie rods on my megane plz?
tomalamix
Re: tie rods
Postby tomalamix » Mon Jan 26, 2015 4:14 pm
what do you mean by the best way? there isnt too much to choose, take one out and put another...the access is very easy if you take the wheel out
phil48
Re: tie rods
Postby phil48 » Mon Jan 26, 2015 6:38 pm
yeh ok thanks
Wickydude
Currently Drives:: Megane III estate 1.5dci 110 Limiited 2016
Re: tie rods
Postby Wickydude » Tue Jan 27, 2015 5:34 pm
count the number of turns when you take it off the tie rod. That way you know how far to turn the new one on.
It's not exact (due to differences in manufacturing), you'll need an alignment check anyway, but at least you're somewhere close.
Re: tie rods
Postby AlexB » Tue Jan 27, 2015 6:17 pm
Video:
https://youtu.be/d3QI_S37JGU
Yes, find a way to preserve the settings. Keep in mind that the rod end may be slightly different if comes from a different batch.
Do tracking by the optical method - aim by a naked eye along the front wheel and at the rear wheel. Find the toe-out values in the manual and calculate the offset, they are specific to the engine.
phil48
Re: tie rods
Postby phil48 » Tue Jan 27, 2015 7:43 pm
THANKS FOR THE REPLYS BUT ITS NOT THE TRACK RODS ENDS IM DOING ITS THE TIE RODS WHICH COME OUT OF THE RACK THANKS PHIL
Wickydude
Re: tie rods
Postby Wickydude » Tue Jan 27, 2015 8:04 pm
You don't need to shout mate :(
Apologies, I thought you meant the rod ends as that's usually what needs to be changed.
Don't know much about the rest of the rack, sorry.
Best download the manuals from the Problems section. MR364Megane3 should have some info on the steering rack.
Re: tie rods
Postby AlexB » Wed Jan 28, 2015 3:43 pm
Those are easy to replace. Turn the steering to the full lock, grab the joint housing of the rod with some tool and turn it gently. Careful, it is possible to damage the rack if the thread is overly tight. In my case, it wasn't tight at all. Put it back with a threadlock.
I used the replacement kits made by TRW, they come with everything including the rubber boots. I used this wrench to grab the joint (the toothed jaw). The space is limited, so I recommend this one.
Bahco 9072P Rev Ergo Adjustable Wrench 10"
phil48
Re: tie rods
Postby phil48 » Fri Jan 30, 2015 5:43 pm
Wickydude wrote:You don't need to shout mate :(
sorry didnt relise caps lock was on wasnt shouting thanks for the reply
phil48
Re: tie rods
Postby phil48 » Fri Jan 30, 2015 5:45 pm
AlexB wrote:Those are easy to replace. Turn the steering to the full lock, grab the joint housing of the rod with some tool and turn it gently. Careful, it is possible to damage the rack if the thread is overly tight. In my case, it wasn't tight at all. Put it back with a threadlock.
excellent thankyou doing them satuday thanks all for the replys cheers phil
Users browsing this forum: Google Adsense [Bot] and 47 guests
