DPF
sanmiguel
Currently Drives:: Megane 1.9 dci (53)
DPF
Postby sanmiguel » Thu Nov 27, 2014 3:56 pm
Possible dumb question, but here it is...
How do I know if I have a DPF - car is Megane 1.9 dci on a 53 plate
The toxic fume (engine shaped) light has come on :-(
morganjake1544
Re: DPF
Postby morganjake1544 » Thu Nov 27, 2014 7:04 pm
A '53' plate does not have a DPF so it's something else.
sanmiguel
Re: DPF
Postby sanmiguel » Thu Nov 27, 2014 10:25 pm
Possibly related to the check injection message that came on a few weeks ago. Both lights have now gone out.
sanmiguel
Re: DPF
Postby sanmiguel » Tue Dec 02, 2014 9:03 am
Ok, the engine light has come back on again (toxic fume)
Any clues as to what to check before I go and pay stupid money for a garage to have a look :cry
taffyhl
Re: DPF
Postby taffyhl » Tue Dec 02, 2014 10:03 am
Buy a cheap Bluetooth OBDII reader and download TorquePro app (or similar) on your phone - around £10 for both. Use this to see what error codes are being shown and google the results.
Could be anything but mine was the EGR valve gunged up and stuck, as reported by OBDII. Cleaned it up and no errors for last 2 years.
sanmiguel
Re: DPF
Postby sanmiguel » Tue Dec 02, 2014 12:03 pm
Is it worth using the EGR cleaner, or stay away from it?
https://www.amazon.co.uk/Wynns-23381-Die ... 44&sr=1-12
freelanderuk
Re: DPF
Postby freelanderuk » Tue Dec 02, 2014 2:38 pm
For the time it takes I would take it off and give the erg valve clean, I don't think the cleaner would get threw all the oil and soot to clean it properly
I had my dpf removed after it would not regen and the engine remapped, had its first mot since it was removed yesterday and no problems with the mot
Drive it like you stole it
My flickr
taffyhl
Re: DPF
Postby taffyhl » Tue Dec 02, 2014 4:23 pm
You need to take the EGR valve off to check it anyway as it may not be too bad. If it is then it would need to be removed to clean it properly - search the forum for instructions as many have done it before. Main thing is to separate the solenoid from the mechanical valve itself so the latter can be given a good soak without risking getting the solenoid part too wet.
If it is gunked up check the inlet manifold to make sure the holes which match the egr valve holes are clear too. Mine were blocked.
sanmiguel
Re: DPF
Postby sanmiguel » Wed Dec 03, 2014 8:31 am
Sounds like a job for the weekend. Funnily enough, the light has gone off again
Think I will check it all anyway (after I search for the "how to" guide)
Cheers for the help :-)
Users browsing this forum: No registered users and 52 guests
