resetting windows on a cc convertible
dieselccconvertible
Currently Drives:: megane mk 11 1.9dci cc convertible
rover 75 connoisseur se diesel tourer
rover 75 connoisseur se diesel saloon
motorhome
suzuki rf600 r
Postby dieselccconvertible » Sun Aug 24, 2014 11:01 am
i am trying to reset the opening and closing of the windows when operating the cc convertible
what happens is
all the windows close when you take the roof off and the passenger window goes down!
it is the same when you close the roof .... any ideas :roll: :roll:
Crewzin
Currently Drives:: 2005 1.9 vvt cc
Re: resetting windows on a cc convertible
Postby Crewzin » Tue Aug 26, 2014 12:36 am
I have a very similar problem. Rears dont go down on all down switch but do on their own switches. If open and i open the roof drivers rear closes! I am at a loss!
FEWRIOUS
Currently Drives:: 2005 Megane CC
Postby FEWRIOUS » Wed Aug 27, 2014 8:50 pm
Bit of a similar problem apart from 3 of mine go down via centre button but the 4th one won't but will work via drivers unit, been told 99% of these problems lead to the temic module sensor, Renault have quoted me £150 fitted to fix this problem which is at a reduced rate due to them knowing about this fault as they don't sell temic separate it only comes with complete regulator and motor but if you look on eBay you can get your old ones repaired or buy aftermarket ones which are plug n play for about £40 a pair, so I'll be going down this route first before parting with £150, I'll keep you posted and let you know if any joy :cool:
Users browsing this forum: No registered users and 76 guests
