Diesel engine cab pre heater..
petepete
Currently Drives:: cc
Postby petepete » Sun Jul 13, 2014 8:28 am
I am not one to rough it and have had a diesel pre heater i picked up for £50 waiting to be fitted to a car i intended to keep a couple of years...
https://www.youtube.com/watch?v=1KByh2nHq5c
I use one on the motorhome run off a sepperate tank of red diesel and cant think of a better modification for a megane cc to clear all frost and ice and make it easy to live with in winter conditions...
( i might have to remove the battery to the rear to find space to fit it )
Meganeccdarren
Currently Drives:: Megane cc
Re: Diesel engine cab pre heater..
Postby Meganeccdarren » Sun Jul 13, 2014 8:00 pm
petepete wrote:I am not one to rough it and have had a diesel pre heater i picked up for £50 waiting to be fitted to a car i intended to keep a couple of years...
Is it really worth it, my 2.0T takes a couple of minutes max to warm up, why go to all that bother?
petepete
Postby petepete » Sun Jul 13, 2014 9:30 pm
why bother... :hm
I m high up, in winter the air is damp and frosts regular 4 months of the year never mind the posibility of snow and I have an erbespacher kicking around :wink:
It takes me 10 minutes to defrost using 5 watering cans of hot water much of winter and if i can avoid that on a morning baisis never mind the problems at the end of the day parked away from home i bloomin well will !!!! :grin :grin :grin
Meganeccdarren
Postby Meganeccdarren » Sun Jul 13, 2014 9:34 pm
Ah ha, well that may be worth bothering then. There is another solution, well 2
1- build a garage
2-move to Spain
Lol
Only messing, will you need to inform your insurance company though? Where will you run the diesel from ?
Darren
petepete
Postby petepete » Wed Jul 23, 2014 3:06 pm
well, here is the diesel heater...
https://screencast.com/t/sUDHNLND
Today I ran it for the first time in a year and it fired up ok and heated 15 litres of water to 75 degrees c in under five minutes using a 1/8 of a mug of diesel and i had forgotten how much they sound like a jet engine
without the silencer i use on the motorhome and wont be bothering with on the car :grin :grin
It looks as if there is space to fit it under the battery simply by removing the nearside arch liner to gain access and saves the job of moving the battery to the rear as i previously envisaged. I have test proven the heater
blower on the car by supplying it with a live with the ignition off ...
A small 4l red diesel tank will fit in the boot below the shelf feeding the diesel heater via a fuel pump and a 4mm fuel line run under the car.
( i did hit a snag - with the doors locked and alarm on the alarm senses the current draw and activates )
I am only short of a £5 remote control and the rubber water hose needed to couple into the cars heating system :-)
I will fit it in 4 stages as and when (pump mounting, fuel tank and supply, electrical, and water circuit)
Looking forward to a pre heated, defrosted car in winter with no cold starts ! :wink:
