Wires hanging down underneath seat, no air bag lights come o
Cld83
Currently Drives:: Renault megane 1.6
Postby Cld83 » Thu Jul 10, 2014 3:57 pm
Hi I'm new here and looking for a bit of advice. I have jut bought a megane 1.6 vvt 2002 from a private seller. The seats were not working(which I have now fixed) and when I looked underneath there is hanging wires and I don't know what they are for, I also looked under the dash and a wire has been cut. The wires under the seat are like a roundish blue connector then a small white connector. The one underneath the dash I green sorry if this is not enough information. I have took pics but I can't seem to upload them. I would be grateful if anyone can tell me what they are for.
Thank you
TAS
Re: Wires hanging down underneath seat, no air bag lights co
Postby TAS » Thu Jul 10, 2014 5:07 pm
The one under the dash could be from the clutch pedal switch (2 pin green connector). They always break and hang down.
Upload your pics to imgur.com and post the link so we can have a look to confirm.
Andy
Cld83
Postby Cld83 » Thu Jul 10, 2014 5:52 pm
Postby Stranger » Thu Jul 10, 2014 6:54 pm
Postby AlexB » Thu Jul 10, 2014 7:38 pm
2002? What generation Megane is it? How many doors are there? Quoting the model code from the oval plate might help.
The first photo looks like a clutch pedal switch. The other one I don't recognise. If dealing with electrics, I highly recommend to download the factory manual and the circuit diagrams. They are in the sticky thread with an appropriate subject line.
If the seat is disconnected, this must trigger the warning light. Something is done there to prevent this from happening... Check if the car is safe!
Meganeccdarren
Currently Drives:: Megane cc
Postby Meganeccdarren » Thu Jul 10, 2014 7:47 pm
AlexB wrote:2002? What generation Megane is it? How many doors are there? Quoting the model code from the oval plate might help.
Unless of course the dash light has been disconnected Alex , I've seen that before on a 20v new shape beetle!
Cld83
Postby Cld83 » Thu Jul 10, 2014 8:05 pm
Thanks for the replys. It's a 52 second generation 3 door megane. No warning lights are on dash so I was thinking maybe something has been unplugged but I don't have a clue.
Meganeccdarren
Postby Meganeccdarren » Thu Jul 10, 2014 8:27 pm
Do the lights come on when you turn on the ignition, before you start the engine?
Cld83
Postby Cld83 » Thu Jul 10, 2014 9:11 pm
No. Only the abs, battery and engine. And oil light come on
Postby AlexB » Sat Jul 12, 2014 4:39 pm
Here you go, disconnected. It's quite possible that the car was in a collision at some point. Apart from the restraint system, you need to check structural integrity of the body shell, crample zones, suspension, brakes and steering. Cars fixed for sale may also have either damaged, mismatched or budget tyres...
Cld83 wrote:No. Only the abs, battery and engine. And oil light come on
Postby AlexB » Sat Jul 12, 2014 4:52 pm
Yes, you're right, it wouldn't harm to remind everyone that in modern cars the dashboard lights are tested every time the engine is started. If they do not illuminate, the car will fail the MOT.
Meganeccdarren wrote:Unless of course the dash light has been disconnected Alex , I've seen that before on a 20v new shape beetle!
Cld83
Postby Cld83 » Sun Jul 13, 2014 8:30 pm
Thank you for the replys, I will get it checked over.
