Won't start + 'Braking Fault' error
kribon
Postby kribon » Sun Jan 30, 2011 3:06 pm
Was wondering whether anyone has experienced the same problem with their Megane Coupe Cabriolet. Mine is a 2007 reg, and is a Dynamique Diesel 1.5 DCI.
When the weather went really cold in Nov/Dec it began playing up to start. I'd hit the Start button, it would try starting and then on the 5th or 6th go it would finally start up. At times, it also gave the error "Braking Fault " on the display. However, it still started up eventually. I took it to garage as I thought it was a battery problem. They checked it out and said battery was perfect and the alternator was perfect too. They put it down to the very cold weather!
Today I tried starting it, the car has power (radio & windows), but no matter how many times I try starting it just wont start up. Again, it displays the message 'Braking Fault', but not everytime I try starting. It seems to be a random error message. The orange coil symbol appears normally when hitting the start button, goes out, and then the car attempts to start.
Can anyone help with this please? I just dont know what the problem could be.
Kribon26
Ray
Re: Won't start + 'Braking Fault' error
Postby Ray » Sun Jan 30, 2011 3:29 pm
try topping up the brake fluid
mihailolja
Currently Drives:: Renault Megane 1.5 Diesel 2006
Postby mihailolja » Mon Mar 10, 2014 8:20 am
Hi there,
Do you remember how you solved this because my Megane Mk2 Diesel 2006 has exactly the same problem?
Any help appreciated.
Regards
Mihailo
freelanderuk
Postby freelanderuk » Mon Mar 10, 2014 8:42 am
mihailolja wrote:Hi there,
Regards
Mihailo
i would start your own post in the problem section listing as much details as posible ,, this member last visited in Sun Jan 30, 2011 8:50 pm and it was his only post ,
i am locking this thread so it drops of the page
Drive it like you stole it
My flickr
