Engine stalled and now has no electrics
danielhurrell
Currently Drives:: 2005 Renault Megane II Coupe Convertible 120dci
Postby danielhurrell » Sat Feb 08, 2014 12:03 pm
Hi
Ive tried searching to see if this problem already exists here but cant find it yet.
Basically i was driving home the other night. Stalled at a roundabout and now the only thing the car will do is hazard lights and lock / unlock. No lights, wont start etc. I had to get the car recovered.
Ive checked all the fuses and none are blown.
The car was running fine before and i do around 300 miles per week. No known issues. When i stalled there was quite a joult but that was me on the clutch. Car is fully serviced at regular intervals.
If any one has any ideas i would be extremely grateful.
Thank you
Re: Engine stalled and now has no electrics
Postby AlexB » Sat Feb 08, 2014 7:26 pm
Check if the access hatch cover is in place on the front left wheel arch liner.
danielhurrell
Postby danielhurrell » Sun Feb 09, 2014 11:16 am
The cover is in place. I have removed and checked the engine fuse box to check for water and blown fuses but all are fine. The start button lights up and you can hear a click when pressed. around 3-4 seconds after this is pressed there is another click. Thats all its doing. No lights on dash at all. no radio etc
blueboi2
Currently Drives:: 2003 renault megane 1.5 dci
Postby blueboi2 » Thu Mar 27, 2014 11:49 am
I had a similar problem and it was water in the fuse box needed a new fuse evans halshaw charged me £368 now I have put a plastic bag over the fuse box to save it a bit. hope this helps.
Users browsing this forum: No registered users and 53 guests
