airbag ecu part no.
Discussions around the Mégane 225.
jayk
Re: airbag ecu part no.
Postby jayk » Thu Jan 30, 2014 9:36 am
yeah, Renault didn't charge me this time since they didn't get the job done last time. I already lost confidence. There are many airbag wiring looms on web but none of them looks like the one hidden on the roof. it's gonna take me more time to search it
Postby AlexB » Sat Feb 01, 2014 10:02 am
Isn't it easier to repair the connector or the wire?
If you buy the loom, the old removed one will sit on your floor, with all wires and connectors exposed and ready for testing and repair. So, you can go with repair in the firs place, instead of buying... An even better option is to test it thoroughly in situ.
booktrunk
Currently Drives:: Megane CC '55 Plate
Postby booktrunk » Sun Apr 03, 2016 1:15 pm
I had a warning on my Megane. Sounded like it would be expensive.... Ended up wiggling the cables under the passenger seat and checking it was all connected up tightly and light went away.
Postby AlexB » Sat Apr 09, 2016 7:14 pm
Spray the connector and the seat position sensor with plenty of WD40.
Return to “Megane 225”
