Got an advisory on rear discs which we knew may be an issue due to the previous owner hardly using the car and the discs where slightly pitted, I have brought replacement discs and pads and these will be replaced when my hubby gets round to it
Also got an advisory on 1 rear tyre. I have checked my tyres and on the rear I have Continental sport contacts, 1 is almost new 8mm and other one is only 3mm? I suspect the previous owner replaced 1 tyre early due to damaged as when I purchased the car 1 alloy was badly kirbed and had a brand new tyre (I repaired the damaged alloy wheel) How many miles do you think I can get out of the 3mm tyre? I have brought a part worn Continental to match the new one which is 6mm. I'm planning on waiting untill the 8mm tyre wears down slightly to match. On the front I have cheep nasty infinity tyres that are like new 7mm, which I never would have chosen myself. I can't decide weather to use up the fronts or buy better tyres.
Also changed the numberplate to a personalized one at the weekend, so it now really looks the part
