Sloshing sound !!
DaiTurbo
Sloshing sound !!
Postby DaiTurbo » Thu Jan 23, 2014 8:19 pm
Seems to be coming from somewhere on passenger side of car (like a half empty bottle of water sloshing to end of bottle).
Have felt carpets but all seem dry.
Very little condenstation in car.
Have took grommets out of door but nothing seems to flow out.
Any ideas please ??
freelanderuk
Re: Sloshing sound !!
Postby freelanderuk » Fri Jan 24, 2014 6:32 am
Have a read hear viewtopic.php?f=2&t=12727
Drive it like you stole it
My flickr
JamesCC
Postby JamesCC » Sat Jan 25, 2014 10:48 am
Agreed as above it happened on mine a couple of times after heavy rain but seems to go in an hour or so.. May try cleaning mine just for a servicing sake
freelanderuk
Postby freelanderuk » Sat Jan 25, 2014 11:41 am
i have just had to clear mine again :(
My flickr
DaiTurbo
Postby DaiTurbo » Sat Jan 25, 2014 1:58 pm
Have just looked into bulkhead and can't see any standing water.
So does it stay in the tube or something ??
freelanderuk
Postby freelanderuk » Sat Jan 25, 2014 2:31 pm
If the drains are blocked you will see the water , mine was about 4" deep until I poked the drains to dislodge the obstruction, with the bonnet open I removed the secureing clip and just lifted the scuttle panel up enough to get my hand in with a piece of stiff wire to prod the drain
My flickr
DaiTurbo
Postby DaiTurbo » Sat Jan 25, 2014 4:29 pm
Just poured warm water down both sides of bulkhead. Water flowed straight thru to behind wheel arch area.
So don't think blockages are my probelm.
Any other ideas ??
Postby joeishmather » Wed Jan 29, 2014 8:43 pm
Is it in the passanger door? If you open the door and swing it side to side you should hear it if it is..
