need the front lower
- Currently Drives:: Renault Megane 1.4 16v Sedan
Re: need the front lower
aye i know ill be real close to the floor i may get higher profile tyres so its not as bad well im hoping anyway haha do you have a pic with springs in mate?
dayumm man thats so smart how bad do you struggle with speed bumps? i scrape a few down my end as it is can see this being a problem haha
Have to be pretty strategic on most but its not too bad, its the subframe tats hits more often than not but if you go think about it its not too bad
this is probably a silly question but if you damage the sub frame isit bad? and do you have specs for your front springs the company you advised got back in touch and said send them or send specs but i need the car for work so sending isnt an option
if you do have the specs would be much appreciated! cheers
It would have to be a big shunt to damage the subframe! And spec wise i said just compress them 60mm at the tighter wound end
Hey back again just wondering do you have the specifications for your springs after they was compressed? cant afford to have mine out because my car is for work and ive found a firm that cant make complete new ones and JOM dont seem to want to message me back haha any help would be appreciated!
I dont have specifics unfortunately cos i took mine off to be done. Iv got standard suspension if you wana bang that on for a week or so till you get it sorted
yeah i would haha but its my cousin who is the mechanic not me haha and i binned my old springs/shocks :/
- MilosB
- Currently Drives:: R. Megane 2 1.9dci sport package
way to low profile tire there man, a 225/40 on 18 is the minimum and even they look skinny and small, 205/40/17 are to small if you ask me, and the bigger tire will fill the arches much nicer, and you can raise the car a bit, and have better ground clearance.
Correct, thats why i went from 17s to 18s, but the hole point of fitting the porsche wheels n goin low profile and low suspension is to get it scraping its belly, thats the hole point of it! If i wanted ground clearance id have got a 4x4 or left it standard
i scrape most things
its all good jsut gotta be abit slower wich i dont mind and craig would i be ok borrowing them front springs/shocks when i can arrange fitting and my other springs to be compressed ill give you a deposit sort of thing to make sure you get them back haha
Yeah course dude, just as long as they come back!
Where abouts are you?
Im in lincoln but i dont mind a drive within reason haha suspension and exhaust is last thing im wanting to get done at the moment so would be much appreciated
Would be a bit of a treck but its all at my old mans near wakefield
