I DID A SERVICE ON MY 1.5DCI MAXIM YESTERDAY,
WELL AFTER PUTTING Mobil 1 0w40 IN IT I CANT BELIEVE THE MASSIVE DIFFERENCE, THE ENGINE RUNS SO SMOOTH AND MUCH MUCH QUIETER I AM SO IMPRESSED WITH THIS OIL,
HALFORDS £49.99 COSTCO £29.99
THANKS TO alexb, MY DCI IS RUNNING BEAUTIFULLY!! CHEERS FOR THE ADVICE BUDDY!!
BEST OIL BY FAR!!!
Mobil 1 0w40 IS THE BEST FOR YOUR MEGANE
Re: Mobil 1 0w40 IS THE BEST FOR YOUR MEGANE
Thanks for the good words.
What's next? The gearbox oil or the brake upgrade? Both or any of them will give you the same level of satisfaction!These can wait until warmer weather though.
Will this oil be ok for my 1.9 dci.
Cheers longy.
Cheers longy.
- Currently Drives:: megane 1.5 dci maxim 5door, silver
Your welcome alex,
i really can not believe the massive improvement!! it runs so quiet its like driving a petrol car, all i hear is the nice smooth whistle of the turbo, really chuffed now, silky smooth,
Alex, What oil would you advise for the gearbox ?
Is it a straight forward job?
thanks again,
Ps, to the person who asked if the oil will be ok for the mighty 1.9dci, the answer is YES ! as that is the engine alex has.....
thanks again,
I use Motul Gear 300 75W-90 Racing gearbox and differential lubricant 100% Synthetic – Ester based, bought from opieoils. There is sale now, plus a discount for our club. This oil is good for all Meganes apart from RS with Lim Slip Diff, for which it is too slippery. I needed two bottles, check how much your box takes!
https://www.opieoils.co.uk/p-899-motul-g ... based.aspx
The job is a bit fiddly without a lift. One can use a plastic tube from B&Q to extend the nozzle on the oil bottle in order to feed the oil from above the engine rather than struggling under the car. In this case you need two people: one is watching below, and one is squeezing the bottle above. The oil flows slowly, it might take 15 minutes or so. Have a look in the manual for the location of the plugs. Basically, you keep adding oil until it overflows. Then you screw the plug in (I mean the plastic one on the side of the gearbox). There is also a metal plug for draining old oil.
once again alex thankyou, i will update soon when i have do the oil change
rgs daz
rgs daz
dazbex wrote:Your welcome alex,
thanks again,
Cheers for that.
- Currently Drives:: megane 2 privilege
I agree mobile one 0w/40 is very good I have just done a oil change on my 1.6 and noticed the difference it's a different engine now
- Rally Driver
is this the oil your on about
Mobil 1 Turbo Diesel 0W/40 5 Litres
Yes.
Turbo diesel or not, it comes from the same tap. The TD version does not have the petrol accreditation, which helps Mobil to save a couple of pennies on the stamp.
- Rally Driver
thanks , its on offer at halfords this weekend £34.99
Users browsing this forum: Google [Bot] and 78 guests
