Front scuttle drains
Discussions around the Mégane 225.
galaxy273
Currently Drives:: MEGANE 225
Postby galaxy273 » Thu Jul 19, 2012 9:28 pm
Hi my front wiper motor is sitting in water
how do I clear the front scuttle drains
Suggested that I need to remove the plastic trim above the wiper motor can I clear from wheel arch?
Any tips on removing the wipers? nuts come off but blades are stuck how much force is safe to use.
Thanks Galaxy273
Re: Front scuttle drains
Postby davelowe » Thu Jul 19, 2012 10:02 pm
I don't have a 225 but the last time I did this job, I bought a small puller for about £3 from the local parts supplier. The splines can get very tight. If necessary, leave the nut on but loose to avoid damaging the thread. You might be able to tug/pry it off, it depends on the situation...
Mark the position of the wiper blades on the windscreen using tape before removing them - that way you will put them back correctly.
Return to “Megane 225”
