Not happy with my wipers on the cc, fleabay has these, are they suitable? Just they seem rather cheap @£6. Or is there anything better?
http://www.ebay.co.uk/itm/24-18-Aero-FLAT-Windscreen-Front-Wiper-Blades-Renault-Megane-Cabriolet-Mk-II-2-/310350840147?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item48425a0153
Are these suitable wipers?
- Currently Drives:: Renault Megane II 1.9 DCi Coupe Cabriolet, in Champagne
'55' Plate Megane II cc, 1.9DCi, in Champagne, not Gold like the book says!
Re: Are these suitable wipers?
probally be ok at that price its worth a try, what you will possibly find that in the winter when it gets cold they will harden and bounce, I bought a set of Aero wipers from fleabay around 3 years ago still using them as the plus side is if you are careful you can remove the plastic end cap and replace the rubber blade you just buy a longer blade and cut the ends off it will be obvious when you see the two together normal blades have a thicker bit with a slot in at either end to locate them the aero blade does not the plastic caps stop them being pulled off the blade arm I noe ortate two sets the last set bought from Aldi for a £5 and they do exactly the same thing with the end caps.
AND.... the car does look better with them!
Thanks, Ill give em a try...
Just arrived in time for a downpour. Soooooo much better
