panoramic sunroof sticks when trying to open
NDT100
Currently Drives:: 1.6 Renault Megane 57 plate 43,000 one owner full service history
Postby NDT100 » Thu Apr 26, 2012 8:17 pm
Hi has anyone had the same problem ?> ive got a 1.6 Renault Megane 57 plate, The sun roof seems to stick when trying to open it after a few trys it does open sometimes i need to push up by hand Appreciate any advice Thanks Neil
Re: panoramic sunroof sticks when trying to open
Postby AlexB » Fri Apr 27, 2012 4:19 pm
No idea, I don't have one. Try reading the manual in the sticky thread first.
Don't you think it needs sun to operate?.. :jest
liamhoughton317
Currently Drives:: megane II 1.9 dci dynamique
Postby liamhoughton317 » Sun Apr 29, 2012 1:16 am
my sunroof had the same problem. i fixed it by opening the roof to half way, then removing the two T25 torx screws on either side of the window when looking at the sides from inside the car, then carefully undoing the T25 screws on the rear runners. with some assistance lift the glass over the car and rest it somewhere safe. then get some silicone GREASE not spray. then put some in the runners and move the rear runners back and forth a bit to spread it about.
you could put a light smear of silione grease on the sealing rubber to soften it up again. dont worry the silicone grease wont have an advere effect on the rubber. that fixed mine
hope it helps :)
Taters
Currently Drives:: Megane 1.5dci 80bhp
Postby Taters » Mon Apr 29, 2013 8:47 am
It's more likely to be worn rubber feet/bushes on the lifting bracket. Do you get a rattle when driving ? Open the sunroof to first setting , look on side of sunroof where the torx bolt is and where the bracket goes into the runner you should see two rubber feet/bushes.
There is a replacement via Renault but they want £80 !!
Quick look on eBay.co.uk and they are around £20, but no idea how good quality they are.
s88urd
Postby s88urd » Thu Jun 27, 2013 4:29 pm
I got a replacement set for around £8 on ebay. I have replied to a previous thread with links to the plastic bush things and also a link on how to change them :)
seems to be a common problem
aadam7531
Currently Drives:: Megane 2 1,6 16 v
Postby aadam7531 » Thu Apr 23, 2015 8:39 pm
I don't have clue for my one before just clicking. Today in the morning I put on full open and is smooth open... Then smooth closed now again just click... Help,please
Jamesy65
Currently Drives:: Renault megan Mark 2
Postby Jamesy65 » Mon Jan 07, 2019 6:11 pm
My sunroof dose this to can anyone send me link to fix it
Jamesy65
Postby Jamesy65 » Mon Jan 07, 2019 6:12 pm
s88urd wrote:I got a replacement set for around £8 on ebay. I have replied to a previous thread with links to the plastic bush things and also a link on how to change them :)
Can you send me link please
joe12
Currently Drives:: Megane estate 1.5dci 86
Postby joe12 » Mon Jan 07, 2019 7:33 pm
Users browsing this forum: Bing [Bot] and 46 guests
