MEGANE HEADLAMP BULB CLIP MISSING!
martink0709
Currently Drives:: 2007 Megane 5Dr 1.5D 106
Postby martink0709 » Tue Mar 20, 2012 1:06 pm
Hi all
First post, so hopefully someone can help - have looked through the posts and can't see an answer to this one - apologies if its' already been covered! Have a 2007 Megane 5dr with a blown nearside dip bulb - not too big a problem, though I know they're a pain to get to - however when I removed the cover over the bulb housing, the bulb came straight out - there is no clip holding it in place! Clearly its been lost at some point, but thought "no problem, I'll ring up and order one as a spare" - only to be told they aren't available as a spare and that I'd have to order a complete headlamp unit! Any ideas of a source, perhaps off another model, or is it just a case of scouring the scrapyards?!
Martink0709
morganjake1544
Re: MEGANE HEADLAMP BULB CLIP MISSING!
Postby morganjake1544 » Tue Mar 20, 2012 7:25 pm
Here's a bit of lateral thinking for you........
.........get yourself one of those big 3 inch long metal paper clips (they're about a foot long when straightened out) and make yourself a bulb clip using the one from the other headlamp as a template.
The big paper clip will be more than long enough and from what I remember the metal is almost identical in cross section and 'springiness' to a bulb clip.
Worth a go?
Starman
Currently Drives:: Proton 1.6 Lxi Wira
Postby Starman » Tue Mar 20, 2012 7:56 pm
Hi there.
Be careful.. I thought the same thing when Halfrauds fitted a bulb for me. They never fitted it correctly so I tried to sort it out myself. I went back to Halfrauds ranting and raving, blah blah... Turns out they are just a push fit! They do only go in properly in one position, and it's just a bit fiddly! But they do actually push into place. All the above assuming you're fitting standard H7 bulbs into a projector type light!?
Take your time for the first time you do this. It may even be easier for you to remove the particular wheel so you can see a bit more!
Good luck..
J.
:cool:
Postby davelowe » Tue Mar 20, 2012 10:49 pm
Starman may be onto something here: my H7 Halogens are press fit only - neither has a clip. Either it has been lost during the passage of time or else, there was a re-design. Both work flawlessly.
pw981
Postby pw981 » Fri Mar 23, 2012 10:41 pm
I believe that the facelift post 2007 Megane with projector style headlights do without the clip and are indeed push fit only.
2004 Megane II 1.9dCi
Users browsing this forum: Google [Bot] and 41 guests
