Accelerating on its own
jason_2801
Currently Drives:: Renault Megane II 1.4 16v
Postby jason_2801 » Wed Nov 16, 2011 3:18 pm
Hi I have a Megane II 1.4 16v 2003 with fly by wire throttle the revs keep going up to about 2000+ while driving causing it to kind of drive itself, even with the clutch depressed it still does it and will sit and idle at high revs also if I blip the throttle it revs up then stutters a bit then revs back up to about 1400 and just sits there. The check engine light isnt on and I scanned it and it has no faults showing, any help with this would be great as I don't have a clue whats up with it. I also cleaned out the throttle body and it doesnt seem to be sticking at all.
Jason
mattyc25
Currently Drives:: megane mk2
Re: Accelerating on its own
Postby mattyc25 » Wed Nov 16, 2011 5:33 pm
have you cleaned the egr valve?.. they tend to get gummed up too..
Matt
jason_2801
Postby jason_2801 » Wed Nov 16, 2011 7:46 pm
Not yet I shall have a look at that tommorow where abouts is it
jason_2801
Postby jason_2801 » Wed Nov 16, 2011 9:46 pm
Anyone got any ideas on this one
Postby davelowe » Wed Nov 16, 2011 10:33 pm
If the battery is disconnected there is a reset procedure for the ECU to learn the idle and your driving habits.
I've posted it verbatim on here before. But, I think the idea is to start from cold, hold at a fast idle for 15 minutes until the radiator fans have kicked in, then try 15 minutes of mixed mode driving.
If you can't find my original post, bump this thread and I will have a look for it.
jason_2801
Postby jason_2801 » Thu Nov 17, 2011 2:41 pm
Does anyone think this could be a vacuum leak i've just found the connection for the vapour solenoid hose on top of the intake manifold to have a broken clip and its quite loose so ive refitted it with sealer just gotta wait for it to dry now and give it a try
tomalamix
Postby tomalamix » Thu Nov 17, 2011 11:27 pm
dont think so...
jason_2801
Postby jason_2801 » Fri Nov 18, 2011 11:51 am
No that didnt make any difference although if you remove this hose it causes the engine to rev to 5500 ish rpm and sit their till you reconnect it
jason_2801
Postby jason_2801 » Sat Nov 26, 2011 4:24 pm
Still have'nt figured this out ive plugged it into clip and the throttle is at 14% when it should be idling anyone know if this is correct and also is it possible to reprogram the throttle parameters
Postby Anthony » Sat Nov 26, 2011 8:47 pm
Mine shows this percentage at idle as well.
tomalamix
Postby tomalamix » Sat Nov 26, 2011 11:49 pm
but your problem isnt idling, right? you should push the engine until the spot it has problems and then check the %
andylwilson
Currently Drives:: Renualt magane estate 1.6 petrol VVT 54 plate
Postby andylwilson » Tue Mar 06, 2012 11:49 pm
davelowe wrote:If the battery is disconnected there is a reset procedure for the ECU to learn the idle and your driving habits.
I have the same problem unplugged my throttle body to clean it no cant get to idle bellow 1000 rpm do I have to do the same as above
Users browsing this forum: Google [Bot] and 33 guests
