cambelt change 1.5 dci
telboy73
Currently Drives:: Renault Megane 1.5dci
Postby telboy73 » Wed Nov 02, 2011 4:40 pm
Hi, just a quick one, i've heard that it's best to change water pump when changing cambelt. Is this correct? cheers
Re: cambelt change 1.5 dci
Postby AlexB » Wed Nov 02, 2011 4:50 pm
True, unless the mileage is very low.
Postby joeishmather » Wed Nov 02, 2011 6:35 pm
As above, it's because the new belt is tighter and this will put more strain on the pump an often cause ok ones to fail, to replace the pump requires the removal of the belt so itll cost alot more doing it separately with 2x the labour..
morganjake1544
Postby morganjake1544 » Wed Nov 02, 2011 6:40 pm
A new pump is only £20 or thereabouts so makes sense and obviously change the accessories belt as well. And even more obviously don't go to a dealer, go to an independent you trust.
telboy73
Postby telboy73 » Wed Nov 02, 2011 11:07 pm
Thanks for your replies, Much appreciated. Getting job done soon :-)
Postby davelowe » Fri Nov 04, 2011 10:35 pm
Guide price is <£200 supplied (both belts and water pump) and fitted at an independent. Just make sure that they know to set the tension by frequency not 'by hand' (although I doubt it makes much difference, Renault specify it this way and it's how I replaced mine).
Ray
Postby Ray » Sat Nov 05, 2011 4:13 am
i went to a dealer for mine. called the local independants and they were like near the same within 20 quid or so.. some were even higher than renault :shock:
telboy73
Postby telboy73 » Sun Nov 06, 2011 9:39 pm
Thank's Guy's appreciate the responses :-)
lholland421
Currently Drives:: 1.5 Renault megane dci 57 plate
Postby lholland421 » Mon May 07, 2012 8:28 pm
how much did you end up paying for your cambelt change i need mine doing but looking for a price ???? for both belts and water pump.
thanks guys
Postby davelowe » Mon May 07, 2012 9:48 pm
£200 or so as I stated above including parts and labour from a reliable independent. Stick an additional zero on if you go to the dealer.
FYI: It's often a good idea to source the parts yourself to save money. I bought a complete kit (tensioner, belts and pulley from Gates - who I regard as the best manufacturer).
lholland421
Postby lholland421 » Wed May 09, 2012 8:24 am
cheers bud thanks for the advice :D
lholland421
Postby lholland421 » Mon May 21, 2012 7:56 pm
Just had cambelt done, took them 4 hours, i got charged £309 for cambelt and water pump :( would this seem the correct price if they used Renault parts?
also i am thinking of taking it back to the garage tomorrow as the car just doesnt seem to shift any more its just flat. has anyone else had this does the belt need running in?
thanks
lholland421
Postby lholland421 » Mon May 21, 2012 7:57 pm
this was from an independent garage
Postby davelowe » Mon May 21, 2012 9:58 pm
The belt does not need running in. Either you are imagining things, or the cam shaft (twice the number of teeth as the crank) is one tooth out. Some engines will run with this error.
However, the battery was most likely disconnected during the service, so expect the ECU to re-learn its calibrations. Give it a week, and if it's no better, take it back whence it came for further analysis.
That's what I would do in the absence of better advice.
Users browsing this forum: Google [Bot] and 26 guests
