Ipod lead?.. where to drill?
Dwabo
Currently Drives:: Megane 2.0Dci GT (remapped!)
Front & rear HEL brake lines, Uprated Alpine ICE
Postby Dwabo » Sun Sep 11, 2011 3:19 pm
I've just got my alpine HU and it comes with an Ipod lead to connect my phone into it..however the lead connects into the rear of the HU so I am going to have to drill a small hole somewhere to poke the wire and lead through so I can connect it up..
Can you give me any idea where the best place is going to be to drill the hole so I can feed the lead through..
would through the glovebox or through the cubby hole under the strereo be the best place or is there anywhere else that I could use?
Megane GT 2.0dci Remapped by Angel Tuning
Ray
Re: Ipod lead?.. where to drill?
Postby Ray » Sun Sep 11, 2011 3:42 pm
either drill into the cubby holder below the stero
or take the glovebox out, remove the side panel on passenger side and then feed a wire that way from back of stereo - no drilling required then. you can put your ipod around cup holder area.
Dwabo
Postby Dwabo » Sun Sep 11, 2011 4:41 pm
is it much of a job to remove the glovebox and side panel?.. to be honest I dont know where you mean by feeding a wire through the side panel.. Seeing as though I am no where near electrically minded my local car audio place said they will fit it for £20 so I think i'll take it to them anyway.. hopefully they can sort the ipod lead out too and put it somewhere that is out the way and cant see a big hole in the cubby hole!
Ray
Postby Ray » Mon Sep 12, 2011 6:58 pm
no, it's pretty easy. 10 min job. all you need is a screw driver with an appropriate torx head. if you take the glovebox out, you can get to the rear/side of the radio.
