Locking roof in half cocked position?
jamesessexeade
Currently Drives:: Magane 1.9 dCi 130 Privilege Coupe Cabriolet
Postby jamesessexeade » Mon Aug 22, 2011 9:04 pm
Does anyone know if there is a way to lock the roof in a half cocked position? The reason being is to allow access to the seals without losing fingers. Cheers guys.
Get that roof down, and 63 mpg, happy days indeed :)
continentalgt
Currently Drives:: Megane 2.0 VVT CC Dynamique
Peugeot 206 1.4 HDI
Re: Locking roof in half cocked position?
Postby continentalgt » Tue Aug 30, 2011 7:20 pm
I would like to know this also, any ideas? Anyone know what happens if you lower a roof in perfect working order manually and what then happens when you try to get it to work automatically?
Anyone had any experience of opening the roof half way and switching the ignition off?
william john
Currently Drives:: 2007 coupe cabriolet s 1.9 dci
Postby william john » Tue Aug 30, 2011 8:01 pm
I have to hold the switch down for the complete opening or closing sequence. If i let it go at any point the roof or boot stops there and then.So this means i can park the roof in any position for better cleaning access etc etc.
I was under the impression they all operated this way or maybe it,s just mine. I was toying with the idea of sourcing a one touch switch but it,s another thing on my to do list.
continentalgt
Peugeot 206 1.4 HDI
Postby continentalgt » Wed Aug 31, 2011 8:33 pm
william john wrote:I have to hold the switch down for the complete opening or closing sequence. If i let it go at any point the roof or boot stops there and then.So this means i can park the roof in any position for better cleaning access etc etc.
Yes they all work that way however I'd like to be able to open the roof half way and safely leave it there for maybe an hour or two, perhaps even overnight.
jamesessexeade
Postby jamesessexeade » Wed Aug 31, 2011 9:22 pm
I had mine half open, when after half an hour it closed, nearly trapping my fingers when I was vaselining the seals. Made me jump a tad. Hence wanting to know if this is a normal pressure release, or can this be locked :)
continentalgt
Peugeot 206 1.4 HDI
Postby continentalgt » Thu Sep 01, 2011 7:48 pm
jamesessexeade wrote:I had mine half open, when after half an hour it closed, nearly trapping my fingers when I was vaselining the seals. Made me jump a tad. Hence wanting to know if this is a normal pressure release, or can this be locked :)
Exactly what I fear, according to the Renault CD manual there are references to locking the roof when working on it but it doesn't explain how to do it.
andyo15
Currently Drives:: 2004 Megane 1.9 Dci CC
Bmw Z3
Iveco 65c15
Postby andyo15 » Wed Sep 07, 2011 6:37 pm
Hi,opening the roof half way isn't a problem but engine has to be running otherwise it will sink down after a short time,thats how i have wiped seals etc.
2004 Renault Megane Privilege 1.9 Dci CC
midsmikey
Currently Drives:: Hyundai Santa Fe with a diesel tuning box and my lovely wife has a 57plate Megane CC 1.9dci Dynamique with comfort pack.
Postby midsmikey » Fri Sep 09, 2011 12:54 am
Vaseline on Rubber seals!!! :o That will damage them surely?
ChrisM
Postby ChrisM » Mon Sep 12, 2011 10:13 am
No it wont, it is a trick most "split" roof owners use to lub and seal usually for the winter the down side is it attracts alot of dirt but is easily cleaned off in the summer the vasaline fills in little imperfections in old seals to stop those water drips in winter.
