Well, now lets take care of business...this chitty (s instead of C of corse) keycard from Renault. The full story: when i bought the car I had 2 keycards, one only opened the doors and the other only started the car, so i had to walk around always with 2 keycards.
After this, 2 months ago the one that only started the card (this means that didnt give the message "Insert Card" on the dash) started to give me the message "Insert card" with the card on the slot, but during a few days i had to give some small taps on the card (when inserted) for the car recognize it. At this moment i thought: in a few days ill be screwed, the card will stop work, so i took my hands to work, opened the card that only unlocks the car. Now starts the electrical part and fortunately im a guy that can manage, measure and understand the philosophy of this keycards, (its similar to other manufactures but in a keycard format).
Instructions to open the card:
Where, i think that theres nothing on the web as good as this ones, it took me a lot of work and you may do this sticky if you want, pictures and instructions. Please do not dry out your pockets before you try this out and do it your self and exchange ideas with others:
Now its open...you will take 1h-2h, its normal...
I've opened the card that only opens the doors and the coil (looks like a black coin) had a pin dried out from the PCB. Resolder it back and this card now starts my car without any problem, its totally functional!. Check this pictures as reference. The pictures below points out how to where the problem is and also explains how to solve the unlock/lock doors on your Megane:
Now, the development part, i opened the 2nd card and the problem where both, coil with dry solder from PCB and the contact from the battery dried out also. Well, just soldered them back and now it only opens and closes the door ok but still doesnt starts the car. This is extremely odd!. I've made some ohmic measurement on the pins of the coil. The measurement on the card that totally works one that works measure 95ohm (+-) and the one that doesnt work measure 56Kohm. This was a big difference! Then i've placed both cards, one at the time, near the card reader (the one on the car that i think that produces an electrical field that goes thought the coil. The coil, no matter if the card is ok or not it should produce some voltage, its pure physics) installed on the car and the card that works we can measure 12V on the 2 pins of the coil, and the other one doens't even move.
My theory: even if there is something burned out on the board the coil must "produce" 12V like the other, unless the problem is the coil it self. Following this idea i've substituted the coil with a card that i managed to arrange (a free hands model, see pictures below to understand the differences). The problem remains, no 12V peak on when i place the card on the card reader and, of coarse, "Insert card" message.
Model with hands free:
Model without hands free:
The previous ohmic measure comes from this 55,9Kohm resistor. I've soldered this components out and others and measure them outside the pcb. The results are on the picture, but now i have an other improvement: The ohmic measure of the coil outside the PCB should be something around 80-100 ohm (+-). If you cannot get that measure and get something like 59 Kohm or 90 Kohm probably you have a broken coil. The solution is to buy an other coil (i dont know where, but i saw them selling, just search with google, if you find it post it here) and replace it, or, like i did, take out the thin cooper wire until you discover the place where the wire is broken. It worked for me in both coils! Now i have 2 100% working keycards.
For thos who think its strange that with the coil ok ive measure 95 ohm and with the broken coil measured 55,9 Kohm its perfectly normal: the current goes through the "easiest" way, i.e., it goes through the path that gives minor resistance, the 95 ohm path and thats why the difference is so massive. In the broken coil card the "easiest" way is through the 55,9Kohm and on the working card the "easiest" way is through the coil resistance, 95 ohm.
For now the only think that it would be good to get is that someone with more knowledge than me in electronics confirms me that those SMD components are really condensers and confirm their values
One more thing I would appreciate is that some one gets some datasheet of this PCF7947AT (there are variants with /447 or other numbers in front instead of 447) to try to understand how they work and check if they are ok or not.
[img]https://img88.imageshack.us/i/e73609b3febe4014bd4b901.jpg/][img]https://img88.imageshack.us/img88/6184/e73609b3febe4014bd4b901.jpg[/img]
I think thats all we can do for now. If nothing of this tutorial works for you then you probably need to pay Renault big money...
Tomalamix
