Hi All
I got a 2004 1.9d Cab
Can anybody tell me if i can turn the service light off myself without going to main dealer
I done a service on it myself about 5 weeks ago
Service Light Can i turn it off ???
- rjacko
Re: Service Light Can i turn it off ???
Did it myself earlier this year. Think you get use right stalk button to flick to the menu showing milage to next service then just hold the trip reset button on dash. Can't remember if it's in the haynes manual or the megane hand book but its definitely in one of them.
Re: Service Light Can i turn it off ??? PART 2 Cont
Hi Guys
Ye i tryed that fix but it didnt work just changed the millage till next service
I still got the service sign and the engine sign lit up
Any ideas guys
Any ideas guys
- Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
i did mine
put key in slot
scroll to the service needed what ever on dash display
press and hold the left stalk with the 3 dots on wait
spanner will start to flash
keep holding
off it will go job done start can and go
put key in slot
keep holding
You can reset it with an ELM327 interface and software for a laptop. £30 will buy what is required. The same amount will probably be charged by a garage for the same thing - so it's a good investment. You can also read the fault codes that caused the light (more importantly).
