Volumetric sensors
Jonault
Volumetric sensors
Postby Jonault » Wed Mar 18, 2009 9:20 pm
I managed to break the left hand volumetric sensor whilst taking the parcel shelf out. Has anyone ever had to replace one of these and if so, how difficult is it?
Jonault
Re: Volumetric sensors
Postby Jonault » Sat Mar 21, 2009 6:09 pm
If you break a sensor, the replacement comes as a set of two; one transmitter and one receiver and costs just over £20. The control box is located behind the carpet on the left-hand side in the boot (at least for the hatchback). The wires are annotated 'T' and 'R' so it's easy enough to find out which one you have broken by doing a continuity test between the plug and the broken wire. The Haynes manual is sadly lacking in any information about the alarm even though it is fitted to most models.
chavva
Postby chavva » Thu Aug 06, 2009 9:51 am
Just came across this post so apologies if I'm way too late. Same thing happened to me- bought sensors from Renault-£22 inc VAT and took it to an auto sparkie who informed me they were cobra sensors and would have given me them for nothing!! Anyhow he put new sensors on for £25.
The last post is correct-does look easy to do yourself and I might have done so had I read this post prior to having them repaired! ;)
onlyme
Currently Drives:: PUNTO MK2
Postby onlyme » Thu Aug 06, 2009 10:40 am
i thought these were pointles tweeters lol
i have one missing. whats that mean? does it actually effect the car?
Ray
Postby Ray » Thu Aug 06, 2009 5:54 pm
means your alarm isn't working...
onlyme
Postby onlyme » Fri Aug 07, 2009 2:54 pm
well i set it off the other day lol. this was by opening the door through a window mind so.
am i best buyin some new ones?
chavva
Postby chavva » Mon Aug 10, 2009 8:42 pm
Onlyme,
If you have one of the sensors missing you should get it replaced as having only one means your alarm wont be functioning correctly(the volumetric alarm that is). These little sensors detect air movement inside the car.
As has been previously mentioned one acts as a transmitter the other a receiver.
Hope this helps ;)
