hi guys
quick query-
i want to fit alloys to my authentique, which is on 15' steel wheels at the mo- can i only fit 15; wheels without affecting gearing/performance/ speedo etc?
or do the low profile tyres compensate for this if i say go for 16' wheels?
what size alloys?
- Currently Drives:: 04 plate 1.416v authentique pearl black
what size alloys?
1.416v 04 authentique pearl black
- Steel
- Currently Drives:: Renault Mégane III 1.5 DCI110
Re: what size alloys?
keeforelli wrote:hi guys
quick query-
Standard dimensions on megane II is 15": 195/65R15 16": 205/55R16 17": 205/50R17.
205/55R16 is the size of a tyre and not of a wheel. Wheel sizes look differently, and each can accept several tyre sizes. See p.65 here:
https://www.reno.ro/index.php?s=61030756 ... 1627461169
Yours 15' accepts tyres of 205 width, BTW.
If you put bigger wheels on your car you can use a tyre calculator to ensure that the overall circumference of the tyre stays close to the original. This will keep your speedo accurate. Here is an example:
https://www.alloywheels.com/tyrecalc.asp
If you fit non standard alloy wheels note that the offset (ET) is somewhere between 38 and 45 and that the centre hub diameter is 60.5mm.
