front brakes replacement?
lisasdynamique
Currently Drives:: renault megane 2.0 vvt Dynamique
Postby lisasdynamique » Tue Mar 16, 2010 8:32 pm
Hi there i have a 07 megane 2.0 vvt dynamique hatchback.
I am a competent DIY motorist however have never had the pleasure of doing brakes on a a megane and was wondering is there any special tools needed or anything i should be looking for in replacing the front brake pads and discs?
Any help will be appreciated.
Re: front brakes replacement?
Postby davelowe » Tue Mar 16, 2010 11:20 pm
Don't think so - provided you have a 2 foot breaker bar and chrome/vanadium socket.
direstraits
Laguna III Ph2 Exception
Postby direstraits » Wed Mar 17, 2010 6:08 am
Make sure you don't twist the flexible break lines/hoses when you detach the calipers.
lisasdynamique
Postby lisasdynamique » Thu Mar 18, 2010 8:20 am
Thanks for your comments.
rjacko
Currently Drives:: Renault Megane 1.9 dci Dynamique, 3dr 03 reg
Postby rjacko » Fri Mar 19, 2010 9:52 am
May need a star type drive as there should be a counter sunk locating screw to position the disc on the hub. This was seized on mine and had to drill and tap it. You should be ok as mines a lot older so less chance of yours being seized.
Postby AlexB » Sun Mar 21, 2010 11:59 am
The workshop manuals are in the "sticked" thread in our Ownership Problems section.
