Hi there i have a 07 megane 2.0 vvt dynamique hatchback.
I am a competent DIY motorist however have never had the pleasure of doing brakes on a a megane and was wondering is there any special tools needed or anything i should be looking for in replacing the front brake pads and discs?
Any help will be appreciated.
front brakes replacement?
- Currently Drives:: renault megane 2.0 vvt Dynamique
Re: front brakes replacement?
Don't think so - provided you have a 2 foot breaker bar and chrome/vanadium socket.
- direstraits
Make sure you don't twist the flexible break lines/hoses when you detach the calipers.
Thanks for your comments.
- rjacko
May need a star type drive as there should be a counter sunk locating screw to position the disc on the hub. This was seized on mine and had to drill and tap it. You should be ok as mines a lot older so less chance of yours being seized.
The workshop manuals are in the "sticked" thread in our Ownership Problems section.
