Side Panel
Megane1.4i
Currently Drives:: Renault Megane 1.4i Sport
Side Panel
Postby Megane1.4i » Fri Jun 20, 2008 8:14 am
Hi
Im new to this forum but im in desperate need of some help. I have a 5dr Renault Megane 1.4i and recently scratched the side panel on the passenger side above the wheel arch. A couple of people i know have said the bumps on the arch can be popped out, and then sanded down, followed by a re-spray.
Has anyone ever suffered this, or do you have any tips on how to get this replaced at a simple cost? Anything less than £500 would be good. Also been advised to look around at breaker's yards as i may need a new panel completely. :cry
Thanks,
Chris
jooooohn
Currently Drives:: megane 1.9dci
Re: Side Panel
Postby jooooohn » Fri Jun 20, 2008 10:43 am
it can be poped out it will leave a little crease / that will be filled in,sanded down then resprayed no more than £150
Megane1.4i
Re: Side Panel
Postby Megane1.4i » Fri Jun 20, 2008 11:05 am
So do you reckon i should go to Renault regarding this? Thanks for the help/advice.
nickbell69
Re: Side Panel
Postby nickbell69 » Fri Jun 20, 2008 1:39 pm
AVOID Renault at all costs. Look in yellow pages for body repair shops. should be a few local to you. I've just had similar done on wifes 307 and it was £150. The guy said price goes up if damage is near to another panel ie:door as they then have to blend the door as well to get a good match. wifes was above the wheel arch like yours so shouldn't be too bad.
M3gane
Re: Side Panel
Postby M3gane » Fri Jun 20, 2008 3:47 pm
Remember that the wings are plastic so may stand up less well to damage
Deano16v
Re: Side Panel
Postby Deano16v » Fri Jun 20, 2008 7:18 pm
only the front wings are
