Megane II hatchback boot set up
steviedude100
Currently Drives:: Renault 1.9 dci
Postby steviedude100 » Fri Jan 20, 2012 1:26 am
Hi guys and girls, ive got an issue that is driving me insane. i have an 04 plate megane 1.9 dynamic, love the car to bits but every since i have bought it there has been a few issues. One of them being the boot set up, my spare wheel and tools are all loose and they are driving me crazy!!!! went to the renault parts in dunstable and sorry to say but they were useless and wanted to know EXACTLY what i needed. so im here to ask for some help......in my boot i have my spare wheel with tools inside, spare wheel and tools are loose so what secures them and where are the tools meant to be secured? also i have like a flap type thing that is sagging into the wheel .....is this normal or is there meant to be some sort of support to hold the boot floor up?
any pictures or parts numbers would be VERY VERY much appreciated and then i can order the parts i need :D
thanks all
Re: Megane II hatchback boot set up
Postby joeishmather » Fri Jan 20, 2012 9:29 am
You'd be best going to a scrap/breakers yard, then you can open ymthr boot and take exactly what you want, it'll cost you £5-£15 rather than £50/£75 that Renault would charge as I imagine they'd tell you you need a whole new tool set rather than just the holder!
Good luck :-)
steviedude100
Postby steviedude100 » Fri Jan 20, 2012 11:12 am
ive been to two scrap yards now and both had meganes but the boot was completely stripped out, the breaker did tell me there was something to hold the flap boot floor up. even if i knew what i was looking for i could search ebay etc....so a photo of how the boot should be set up would be really helpful
steviedude100
Postby steviedude100 » Fri Jan 20, 2012 2:40 pm
cheeky bump :)
morganjake1544
Postby morganjake1544 » Fri Jan 20, 2012 7:12 pm
If it stops raining at some point tomorrow I'll photograph all the contents and parts for you.
:cool:
steviedude100
Postby steviedude100 » Sat Jan 21, 2012 3:21 pm
you are a legend, i have searched the WWW, and i have found every car boot set up apart from the megane II lol. i have found a picture from renault parts system of components from the boot but it still doesnt help me select the correct items that i need.
thanks very much and i hope to hear from you soon
morganjake1544
Postby morganjake1544 » Sun Jan 22, 2012 4:08 pm
It finally stopped raining so here's what you should have.
1. A top carpet which is fairly rigid and hinged about halfway so you can fold it back.
2. A second carpet which is moulded to the shape of the spare wheel and provides a bit of storage and some support for the top carpet.
3. The spare wheel itself which is secured to the floor by a large plastic threaded nut type thing.
4. A moulded grey polystyrene tool holder for your jack and wheel brace which fits in the wheel well just under the off side light cluster. I've photographed it in position and removed.
5. If you have alloys as standard (a Dynamique should) you should also have the locking wheel nuts in a small plastic case and a set of four steel wheel bolts for use with the steel spare wheel (these are originally supplied in a small bubble wrap envelope).
I think that's it. Hope it's been some help.
You can usually find what you need on ebay if you're patient. There's a tool kit and holder on at the moment and a boot carpet.
http://www.ebay.co.uk/itm/RENAULT-MEGANE-dynamique-2006-TOOL-KIT-/170738440563?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c0cdd973
http://www.ebay.co.uk/itm/boot-spare-wheel-cover-carpet-storage-megane-1-9-dci-3dr-03-08-/250920095570?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a6c00cf52
steviedude100
Postby steviedude100 » Fri Jan 27, 2012 8:54 pm
you sir are a complete LEGEND!!!! i have ordered the tool kit foam and the spare wheel clamp from renault. just need to wait and see if i can find the mould that gives support to the top carpet a little cheaper than that. but thanks very much at least i know what i am to look for now :) once again thanks so much!!!
morganjake1544
Postby morganjake1544 » Sat Jan 28, 2012 5:10 pm
You're welcome.
steviedude100
Postby steviedude100 » Sun Feb 26, 2012 7:07 pm
I have finally purchased everything needed to stop the annoying rattles i was having....i got the spare wheel screw in thing for a fiver, the tool kit holder for 25 and the mould that goes into the wheel and supports the upper carpet for 20.....over all a win and everything for 50 quid. well happy thanks again :D
morganjake1544
Postby morganjake1544 » Sun Feb 26, 2012 7:22 pm
Good to know.
How do people lose this stuff in the first place though! :shock:
