Cleaning roof seals
Joehufc
Currently Drives:: Megane cc 1.9DCI 2004
Cleaning roof seals
Postby Joehufc » Tue Sep 17, 2013 4:00 pm
Hi, I'm very aware of common problems with the megane Cc after much research and now have bought my very own :)
I'm wondering, when I clean the seals on roof, can I stop the roof half way up while running the engine to make easy access to the seals without screwing anything up? (engine running)
freelanderuk
Re: Cleaning roof seals
Postby freelanderuk » Tue Sep 17, 2013 4:43 pm
you can open the roof with the engine running and stop it half way , BUT be very careful as it only stops open for about 15mins and will then start to close . i open up , clean and lube half the seals then open roof fully , i then repete this on the seals i have not done and lube the cables and parts under the rear shelf , use a silicon spray for this and i use silicone grease for the seals
Drive it like you stole it
My flickr
Postby wanda » Mon Dec 09, 2013 5:44 pm
Do you have phase 2?
freelanderuk
Postby freelanderuk » Tue Dec 10, 2013 5:33 am
Hi wanda, if you mean me , yes i do
My flickr
