Passenger side front window went down when I locked the doors. I could not close it, nothing happened when I pressed the buttons. The other windows were functioning OK. I took off the door panel, bypassed the window motor controls, lifted the window by using the motor and after that it started to work normally again.
Everything was OK for 2 days but then again, when locking the doors, the same window went down. El. window buttons did nothing for that window. After couple of minutes the window closed on its own. Now it does nothing when I press the operating buttons. Yes, the other windows, door locks etc. do work perfectly.
Any ideas, things to check, parts to replace? BTW, I was washing the car quite thoroughly two days before the first incidence and used the door locks first time after that when this happened.
Thanks in advance.
Tim
Renault Megane Estate, 1.6l, 2004.
Electric window problem
- rjacko
https://meganeownersclub.co.uk/forum/vie ... highlight=
check this post, was the regulator which went on ours. situated inside the door. was done under warranty by renault.
good luck with it
good luck with it
- nickbell69
- Ray
Tis indeed a regulator problem.
As a backup (shown to me by the an AA man), open bonnet, disconnect the neg power lead, reconnect, press the lock button twice on remote. This should make your window close slowly 2 inches at a time.
Disconnect power lead again and repeat procedure to close window.
Note: It may not work!
Users browsing this forum: Google [Bot] and 73 guests
