front indicator blub wont work but double flashing the side and rear??
jk2k2
Postby jk2k2 » Thu Apr 28, 2016 2:39 pm
hi
new to this... I have a 2004 Renault megane 1.5 dci I don't know why but the front driver side indicator wont flash but its double flashing the side and rear indicator bulbs. I have changed all the bulbs as I though one was blown or was on its way out..... nothing. I have had to take the bumper off to access and remove the lights as the access panel is sooo small. I have checked internal fuses and all seem fine I don't know where the relay unit is under the bonnet.
its driving me CRAZY!!
please any help would be most appreciated.
Thank you in advance :D
:banghead :banghead
RedRedRobbo
Currently Drives:: Megane 1.6 Coupe Cabriolet '05
Re: front indicator blub wont work but double flashing the side and rear??
Postby RedRedRobbo » Fri Apr 29, 2016 8:58 am
The other lights double flash to show that one of the bulbs isn't working. usually it is just because it is blown but a break in the wiring will probably have the same effect.
Charleekap
Currently Drives:: PH1 Megane (2004)1.9 dci Dymanique
Postby Charleekap » Fri Apr 29, 2016 9:16 am
I had a similar issue with mine. When I took the headlight out and looked closely at the indicator housing, I discovered a small hole in one of the prongs which was causing the problem.
Obtained a new from scrappy and not had any issues since.
Worth having a look
