I would like to ask what do I need to buy for reading fault codes on Megane 2. Do I need a special code reader or I just connect cable from car to PC? Which software do I need? I assume that orginal Renault software is expensive, so is there any cheap "copy" software that will do the task?
If any, please post link from ebay.
Thanks in advance.
Fault code reader and software
- Currently Drives:: Megane3 Sports Tourer 1.5dci 110 Expression+
Re: Fault code reader and software
Zvone,
I use OBD Doctor which you can get as free download for the basic version. Full version about £35. Download to your laptop and away you go.
Check their web site for all the options.
https://www.obdautodoctor.com
I have the free APP for windows phones and upgraded to the Pro version for about a £10. I use a bluetooth elm327 adaptor which works really well with petrol engines but not with diesels, bought from e bay for £6. Diesels need another adaptor apparently
Hope this helps
Candleman
Hope this helps
Candleman
How many more times, it's not an estate it's a SPORTS TOURER
Azzuro Blue 1.5dci 110 Expression+ Sports Tourer
I use a blue-tooth elm327 adapter which works really well with my diesel 1.9dci also from eBay for about £8
Guys, thanks for answer, I will check elm327 adapter.
- Currently Drives:: Renault Megane 2004 1.9dci Dynamique
freelanderuk wrote:I use a blue-tooth elm327 adapter which works really well with my diesel 1.9dci also from eBay for about £8
now i wasnt sure wether to buy one or not as on the ad it says Dont work with diesels? :/
thats good to know
there is CLIP and there is the DDT2000 with the VAG KKL cable but the first i know is flawless but expensive, the second is hard to find, more complicated to work and i think it doesnt work on 2005 models and later, but i ask if someone who knows that can confirm this
besides those two is there any alternative to make readings on ABS, Injectors, etc etc? A cheap alternative...
- Currently Drives:: Renault Megane 1.9 DCi convertibale
May I have ebay links for Elm327 that is compatible with 2006 Renault Megane 1.9 diesel CC
I have checked few but it says 'not fit to diesel engines'
thanks
thanks
Users browsing this forum: No registered users and 79 guests
