Hi I'm new to the site. I have just bought a megane 1.6 2003 and I am having problems with the window washers when I pull the window wipers stick back the washers do not work and there is no sound from the washer motor so I don't think the jets are blocked and the wipers don't work either although the wipers work on there own. I have looked in the glove box for the fuse that might work the washers but I am unable to see which fuse it may be.
I hope I have explained this ok but I'm not the best on the Internet.
Clair
Window washers not working
- Currently Drives:: RENAULT MEGANE CC REG 2007 MK 2 1.9 DCI
Re: Window washers not working
Hi. The Stick should come towards you I think!
If the Washer and Wipers are not working when pulling the Stick it possible the wiring within the Stick it self that is at fault Broken Wire or Connect Switch.
I don't think there is a separate Fuse for the Washers.
460316DSG1
460316DSG1
Thanks for the reply. I have also since noticed that the cigarette lighter and the back window heater is also not working could these all be linked
- ikhan
Fuse 'G' (a 15amp fuse in the glovebox) protects the following:
Radio - offset display - headlight washer pump relay - first row cigarette lighter - heated seats - screen washer pump - diesel fuel heater relay - air conditioning control panel - AC control unit - auto-dimming rear-view mirror - Protection and Switching Unit
Heated rear screen is fuse '6' (30amps) under the bonnet.
I would look at these first....
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
