Loss of certain dashboard / radio functions.
AndyWardle
Currently Drives:: 2003 Renault Megane 1.5dCi
Postby AndyWardle » Fri Jul 22, 2011 1:12 pm
Hi everyone, as you can prob see I'm new to the group. I have a problem with my Megane 1.5 dci (2003). I got to work this morning and everything was fine, but when I got out the car I didn't quite shut the door properly and didn't know until I left work.
Anyway, since then the radio doesn't automatically turn on any more, or off for that matter, but will work by pressing the power button. The lights for the A/C and rear window heater do not work, and the dimmer switch for the dashboard no longer works, oh, and the light around the ignition card slot doesn't work any more.
Any ideas? I've heard rumours about fuse 15. Is that a likely cause?
Thank you
tomalamix
Re: Loss of certain dashboard / radio functions.
Postby tomalamix » Fri Jul 22, 2011 4:24 pm
yep, a fuse...
check fuse on position G. probably its wrecked, which cause you all that trouble.
good luck
carlbentham
Currently Drives:: megane 1.6 dynamique
Postby carlbentham » Fri Jul 22, 2011 6:56 pm
Defo fuse mine dose it all the time if I forget to put plug back in fag lighter when keys are in dash hanging down they drop in fag lighter socket and short it out always takes the same features as urs with it
AndyWardle
Postby AndyWardle » Sat Jul 23, 2011 2:27 pm
Thank You for your replies, checked fuse 15 just and its blown so replaced it and its all working fine. must be my keys shorting the fag socket as suggested, time to buy a new cap as i've never had one haha!
