Hi!
Here's me with my first problem.
Today I installed a new stereo, the old one was custom too. The headunit fitted perfectly, and I just plugged in the ISO converter to Pioneer radio adapter, put everything in an it works great. While doing this I disconnected the negative wire from the battery.
As I was driving at night, in one moment all electrics just shut off, the whole car was dark for a second and then it came back to life. I'm lucky the steering wheel didn't lock up. I started driving very slowly, and it happened again. Everything went dark. After a few seconds the car came back to life, with all of the warning lights on. This started happening after 3 hours of driving. I stopped and decided not to move. The car starts normally when there's electricity. So the battery isn't drained. I opened the hood and tapped the cover (couldn't open it because of the screws) of the battery. The cabin lights came to life and went out as I tapped. But I couldn't move the wires from the battery poles, it seems they're fastened right. I noticed that servo started to work better than usually as this started happening. The headlights died and they don't turn on in any condition.
My question is... Could I have caused a short circuit with the stereo wiring (I doubt it would cause problems 5 hours later)? Or is it just a battery contact problem? I know this seems like a simple fix problem and you don't have a crystal ball to diagnose what's wrong with the car, but I'm asking if I may done something wrong with the stereo wiring to cause such drastic problems? The car is a couple of miles from me and I'll be returning to it in the morning.
Electrical problems
Re: Electrical problems
I think contact problem, maybe put some grease, vasoline on the battery terminals and reconnect the wires to them... Also are the terminals clean??
Hope that helps
Hope that helps
joeishmather wrote:I think contact problem, maybe put some grease, vasoline on the battery terminals and reconnect the wires to them... Also are the terminals clean??
Hope that helps
I hope it's a contact problem. I'm really afraid of that happening again, because the wheel locks up. I travel on a road with a lot of nasty corners over the hill and that click the lock makes may be the last sound I'll hear before plummeting over the road edge into a huge fall.
Users browsing this forum: Google [Bot] and 38 guests
