Urgent problem help please! Mot in the morning!
rob_s
Currently Drives:: 106 gti
1.5 dci daily
Postby rob_s » Wed Feb 23, 2011 3:50 pm
Right my mot is currently over due by a week so iv booked init for tomorrow morning! I thought it was march it ran out! Tunes out it was the 17th!!! Of feb!
So iv not used it today and booked the mot,just checking the basics and noticed I have a headlamp bulb out! (drivers side)
No problem I had a spair,so struggled like a fucker getting it in blind as you have to
Turned lights on.......nothing! Still out! :(
Is this a common problem? If so what is it I need it sorted asap to use the car! Can't get to work without it and back in tomorrow night so it has to pas it's mot in the morning
And also where is the under bonnet fusebox? As all I can find is the little one behind the glovebox! And can't find the handbook due to recently moving out and a lot of stuff packed away (hence me missing the mot date aswell) only found out due to happening to be sorting z box out and it was in there! :roll:
Cheers for any help
rob_s
1.5 dci daily
Re: Urgent problem help please! Mot in the morning!
Postby rob_s » Wed Feb 23, 2011 3:51 pm
I'm about to check itx not a dud bulb now by swapping it to pass side
steve-t
Postby steve-t » Wed Feb 23, 2011 4:01 pm
If its the under bonnet fuse you will usually have no number plate lights either
but behind battery black box with a lighteng bolt symbol
its battery out battery tray out ecu teased out the way to get to second level of fuses
Steve
rob_s
1.5 dci daily
Postby rob_s » Wed Feb 23, 2011 4:19 pm
What a pain in the arse that is that is! Just like everything on these!
But I do have every other light on the car bar this one
Gonna go and buy a new bulb just on the off chance this one is a dud
Boomstyliemikey
Currently Drives:: 1.9 130 , remapped, DPF removed, Panel filter, double din
Postby Boomstyliemikey » Wed Feb 23, 2011 5:34 pm
You might of damaged the black plastic clip that you slot the bulb into. I done this the first time i changed my light. Unfortunately I had to go to the scrap yard and take it off another renault. I know this does not help ur case but other than that and the bulb I cant think what it would be
rob_s
1.5 dci daily
Postby rob_s » Thu Feb 24, 2011 8:44 am
Nah the connection is fine
But still got s new bosche bulb last night
Still dead mot in an hour just gonna have to take it and let them fail it and try and fix it
rob_s
1.5 dci daily
Postby rob_s » Thu Feb 24, 2011 11:30 am
Tried it again just before I went and saw my arsewacked the light and it came on lol :s
Anyway mot passed 8-)
Users browsing this forum: No registered users and 84 guests
