Auto Wipers Fault
atsang
Currently Drives:: 04 Megane II 1.5 DCi
Auto Wipers Fault
Postby atsang » Wed Dec 29, 2010 10:21 pm
Hi again,
Got a new windscreen in the car and ever since the auto windscreen wipers dnt work i turn the stick to auto and the wipers wipe once and thats it, all i can do is turn it again and the wipers wipe continually at a higher temp than i want any suggestions?
cheers :D
I LIKE THAT BOOOOOOM BOOOOOM BOOOOOOM!!!
MTX8500's x 2
MTX Sledgehamer Amp
MTX 7402 Amp
MTX 5202 Amp
JL Audio J2 500.1 Amp
MTX Road Thunder 6x9's
Pioneer TS-C131PRS Components
Alpine CDA-117Ri Head Unit
http://www.youtube.com/watch?v=OXeIoaRMY1Q
Re: Auto Wipers Fault
Postby davelowe » Wed Dec 29, 2010 10:29 pm
I've heard in the past that there is a special gel required to refit the rear view mirror (and its integrated wiper sensor) to the windscreen. Failing to use the proper gel will probably result in the auto-wiper malfunction.
dcikev
Currently Drives:: 1.6vvt coupe, 1.9dci scenic
Postby dcikev » Thu Dec 30, 2010 1:44 pm
i had the same problem after having a new windscreen fitted,i bought a replacement sensor of fleebay which was a genuine renault part and the wipers still fail to work on auto! perhaps the system needs reset or there could be damage to the wiring?
Rotrax
Currently Drives:: Megane 1.5DCI series 2
Postby Rotrax » Tue Apr 12, 2011 7:00 pm
I got a new windscreen fitted and soon found out the auto wipers didn't work.
Had a look at the sensor and found that it had not been fitted back in properly wasn't sitting against windscreen leaving a pocket of air. After reseating it against windscreen now working ok.
Hope this works for others too :-)
