my brake lights have stoped working help please
vickyross06
Currently Drives:: megane o5
Postby vickyross06 » Tue Nov 16, 2010 9:32 am
right i new to this but please can anyone help!!!!!!!!!!!!!!!!! my brake lights have stoped working but my high level on is ok! can any one help. now i have tried replacing bulb but that did not work, then tried the fuse which again did not work now im stuck. im due my mot soon so hoping i caqn get it fix by myself. please help!!!!!!!!!!!!!!!!!!!! someone said there was a relay under the glove box which had come loose when i looked it was not this it was not loose!
tomalamix
Re: my brake lights have stoped working help please
Postby tomalamix » Tue Nov 16, 2010 10:40 am
hi there,
you have a brake switch on the brake pedal, maybe its u/s.
cheers
Postby AlexB » Tue Nov 16, 2010 12:19 pm
The circuits of all three lights are connected together somewhere near the tailgate. If one light works, then you need to check the point where these circuits are joined.
vickyross06
Postby vickyross06 » Tue Nov 16, 2010 1:46 pm
hi i will look at the circuits thanks. as for the brake switch under the pedel it not that as the man said if i can still start my car using the brake switch that it would mean that the switch is working, thanks any other ideas!!! :D
vickyross06
Postby vickyross06 » Tue Nov 16, 2010 1:47 pm
oh so if i need to find the circuit does anyone have an idea where this may be?
tomalamix
Postby tomalamix » Tue Nov 16, 2010 9:31 pm
do you have any STOP light working in the rear? Or none of them work?
cheers
vickyross06
Postby vickyross06 » Wed Nov 17, 2010 8:45 am
i only have the one that sits in the boots window i think you call it the high level one. the other ones dont work.
Postby AlexB » Wed Nov 17, 2010 8:20 pm
The three wires to the three brake lights join together somewhere in the rear part of the car, before the connector R2. Then, a single wire goes to the connector R2 located on the floor, near the left side B pillar.
Before digging deep make sure the current does not reach the rear light connectors. Use the voltmeter. If nothing helps, then just duplicate the wires from R2 to the lights...
vickyross06
Postby vickyross06 » Fri Nov 19, 2010 5:20 pm
ok i will try when it light tomorrow, i hope it works might just have to take to garage. is this a known problem?
Postby AlexB » Fri Nov 19, 2010 6:55 pm
Lost ground, poor connection inside the light, blown fuses, etc. faults are known. Yours looks like a broken connection within a 1m stretch of the wire loom, which is new, but fits in the overall picture. Are you sure you've checked the connectors on the lights well? Ask someone to operate the brake and measure the voltage on the connectors. I never needed to trace the wire loom, but, I would imagine, it should not be too difficult.
vickyross06
Postby vickyross06 » Mon Nov 22, 2010 7:06 pm
okies well i know that this may sound really stupid and well i must confess it is. after much stressed time over my megane i decided not to let my parter look at the car and do it myself as he seemed to be getting nowhere wer then was driving behind another megane and realised that we had checked the wrong bulbd and infact that the bulbs where blown so problem solved!!!!! so thanks for everyones help!!!!! hehehehehe
gav1pam
Postby gav1pam » Mon Nov 22, 2010 7:19 pm
:D
tomalamix
Postby tomalamix » Tue Nov 23, 2010 2:14 pm
lool... :D
swede
Currently Drives:: Renault Megane 1.6 dynamique
Postby swede » Fri Dec 03, 2010 10:38 pm
Had the same problem with mine this week. Off side brake light suddenly decided to pack up whilst other and high level working fine. Easy fix according to a mechanic !! looking from rear of vehicle with boot open you see the cables for lights go into main body of car above rear off side wheel. Remove cowling above said wheel and clean electrical connection that is apparently easily visible and problem is sorted.
Good luck !!
Sean
